That looks like clearcoat failure. I have seen that a lot at automatic car washes where they spray a high alkaline or acidic cleaner on the wheels while it's still hot. I'm not sure why it only reared it's head after exposure to Power Clean, but that damage has been slow and gradual. Power Clean only has a ph of 11 and is non caustic...so it wouldn't do that.
That rim will have to be repainted to repair.
this is the only pic i got you can see how it looks like a white film on the rim.
I've had the same exact experience using OPC on wheels. I thought it was a fluke so I tried it on another set or two of wheels and it's as if the stuff just doesn't rinse off the wheels even when rinsed with a pressure washer. The wheels look good at first but after a pressure rinse and then a short drive this white chalky staining appears.
Thanks for posting this info.
As has been suggested, and in your opinion, did you find that this white, chalky staining 'condition' was indeed an indication of clear-coat failure? Or even the "beginnings" of clear-coat failure.
Also...Did you find a remedy for removal of the white, chalky
staining, if it wasn't clear-coat failure?
Thanks for any info you are able to provide...I'm sure the OP, as well as others, will be extremely grateful for your professional evaluation!
Unfortunately I have no photos of this problem but I can say that it definitely is a white chalky residue left behind rather than clear coat failure. Somewhat difficult to remove with just an APC or even with more OPC which suggests to me that it may in fact be slight etching. I used Polish with sealant (Poorboy's) to remove it and it came off very easily. One time I rubbed UTTG into the wheel while doing the tires and that also removed the residue but with a bit more elbow grease. No damage done just "extra work" which I constantly thrive to eliminate.
I've had the same exact experience using OPC on wheels. I thought it was a fluke so I tried it on another set or two of wheels and it's as if the stuff just doesn't rinse off the wheels even when rinsed with a pressure washer. The wheels look good at first but after a pressure rinse and then a short drive this white chalky staining appears. I've had this white chalky staining on black plastic interior parts as well. IMO if I have to go over an interior twice because the cleaner needs to be rinsed off then it's not worthy of being in my arsenal of cleaners. A big waste of time and money if you ask me.
Having said that, I'll say that OPC does work well at getting tough shoe scuffs off of interior parts and that's all I'll use it for anymore.
This post really has me worried, as i have just purchased some OPC to be used to help strip the wax off my paint before i start my 'claying' process... should i even consider using this stuff to strip wax off my paint now?
The finish actually looks scratched from using something too abrasive to clean it, and/or possibly from having brake dust built up on the wheel, as looks to be the case from the spots that remain uncleaned in the pic.
Thank you for your reply.
Perhaps the OP's situation may be alleviated by following your "removal-experience"...It's worth a try, IMO.
^^^ Thanks for your reply Chris! I will follow your instructions.
Thanks Chris! This is info is good to know, as i have aftermarket tint on my windows....
Since you have been using this product so much to strip LSP's, can you provide any insight into the mixture ratio, you use? I had planned on using the Foamaster Foam gun to apply the OPC to the exterior of my truck.
Autogeek Quart Foamaster Foam Gun FREE BONUS
