Klasse Act
- Feb 21, 2012
- 27,829
- 2,931
This thread is amazing....
It could have to do with them being Michelins...
As far as tire foam, I would never expect a tire foam to clean good enough for prepping for a tire coating. They’re simply not made to do that.
Finick, what kind of applicator did you use? Optimum recommends using a microfiber towel. That's not something I can imagine doing, but I haven't used the stuff yet.
In descriptions I read tuff shine and optimum seem comparable and McKee’s and the tac systems sounded similar. Maybe give McKee’s or tacs a try. If I know anyone with Michelin’s I’ll give them a try
I had a not so great experience with the optimum tire coating.
This is my second tire that looks like absolute trash after application. I’m not sure what I can really do differently at this point, as all my tires have been scrubbed, cumulatively, about 8 times with straight power clean.
Almost as soon as the coating touches my tire it dries out and I can’t really spread it around, leading to this streaky horrible appearance.
I don’t know if it’s my tires or what. The first one I applied it to in about 40 degree weather, so I blamed that on me. But it’s 60 today, and I was in the shade. So I’m really at a loss here as to what I could be doing wrong.
Not really looking forward to doing my last two tires If this will he the end result, lol. It’s sad when my tire just looked a lot better without anything on it at all.
I used an applicator. It’s really weird, it just dries so damn fast on the tire. Like I almost want to say within 5-6 seconds it seems like it’s tacky and you can’t spread it without streaking it.
I imagine if I sprayed it I wouldn’t have any issues.
Edit: to put it into context, you had enough working time to use the brush then level it with the microfiber applicator pad? If I started applying at the top of my tire, before I even got to the bottom of the tire it was already black. It would be impossible to have a blue hue all over the tire based on how fast it dries. Unless I used a ridiculous amount, and I already used a ton on that tire. Much more than I’ve seen other people use.
Yeah I was thinking the same thing. If I can figure out how to scrub the crap off I may just clean my tires and leave them naked moving forward. I really hate applying tire dressing lol.
I used a round microfiber applicator on my first tire, and a big foam one on this one.
That looks like a mess. It sounds like the tire is absorbing the product to quickly. Your tires may need to be worked in small sections with additional coats until the tire absorbs enough product. Mckee's and Tuf Shine are similar in that regard with certain tires.
Also 40 degrees is the minimum temp it should be applied.
Curious what type of tire dressing where you using before the tire coating?
I saw the applicator you were using and it looks like it is on the thin side and probably not absorbing enough into the core of the applicator.
Optimum recommends a microfiber towel so maybe try that or one of the more plush microfiber applicators (the blue microfiber versions that are a bit more plush). But put more to have the applicator a bit more damp rather than just a line and work it in small sections.
Optimum recommends using their TAR Remover to remove it as Power Clean will not do it. Perhaps another tar remover will work. If not you will need to remove it like I did with McKee's (the old DP version) based on Nick's information as McKee's is an acrylic coating and a fresh coat is very durable and a paint to remove. I am on my phone at the moment but I am 95% certain that write up is on Autopia if you want to check it out search along the lines of how to remove DP Tire coating
Can you post a photo of this applicator?
All things considered, if I could get it on evenly, I actually like the depth/color one coat seems to produce. I think I'd be happy with one coat on each, so long as one coat on each didn't look like complete garbage, lol.
Yeah, what I meant was just that I gave my first tire a pass, since I did apply it when it was a little cold out.
I was using PERL
Yeah it's pretty garbage, which is why I used it for this task. It was a really bad user experience, too. It just didn't want to glide over the tire. kept trying to rip out of my hands and was just really not enjoyable to use. I like the foam one a lot better.
Found your write up, so I'll probably just save myself some headache and go straight to steel wool. I seem to remember Yvan saying in a video that mineral spirits can be used to scrub the coating off, but I'd have to dig to find that video.
Well it took me all of 25 minutes to seemingly remove it from my passenger front tire
Saw a video posted earlier today where Yvan just scrubbed down the tire in his Jeep with their new tar remover, so I figured I’d go out there and try that with tarx.
Took one pass to get the botched coating off, and I did an extra one for good measure. Followed by a couple scrubs with pure power clean.
Didn’t take a picture of the tire before, but it looked similar to the front driver side tire I posted about before.
I may give it a couple more scrubbing and try again on that tire, lol. Now that I know it’s pretty freakin easy to remove.
I guess to be fair I did scrub at it with the tarx on there for a good while using a short bristle brush, but if you watch their video on Facebook of them doing the same process with their tar remover it’s the same result.
I only had to touch up a couple spots, and there’s the little patch from where my tire was against my driveway I’ll take care of it when I get home.
I guess time will tell how it holds up once more people are using it on daily drivers. I’ve seen fairly good results from people using it on the optimum Facebook group so far.
I see that Tar-X's most active ingredient is Petroleum Distillates (55-65%). Didn't try any Lacquer Thinner when trying to remove the Tuf Shine.
I'm not sure I would lump lacquer thinner into petroleum distillates and consider them to be equivalent, if that's where you were going.
Lacquer Thinner will clean tires up very well. Only thing I have found that can remove Armor All.
Any long term updates on Optimum Tire Coating?
