I have some very light orange peel on repainted panels. You can only see the waviness very up close but it does effect the reflection quite a bit.
My question is what should i do to remove it, i found these pads:
Monello Senza Arancia Orange Peel Sanding Pad 2000grit - 2-pack - 4"/100mm | Carclean.com
They are made to be used with a polish and claim to remove orange peel and leave a cleaner finish so less polishing is needed. They supposed to be used with a machine but i don't have that so i would do it by hand.
Or would for example a 3000 grit wet sand be better. I don't have a machine polish so it will have to be polish by hand afterwards.
