The orange Hybrid pad is the most aggressive
After that the other two are probably going to provide close to the same aggressiveness if used with the same liquids. The MF pad is softer than the orange CCS pad just to your sense of touch but because it's made p of individual fibers it does offer cutting action like an aggressive foam formula.
What are you working on?
What are you trying to do?
I really like the hybrid pads for rotary buffers and the Flex 3401...
:xyxthumbs:
:xyxthumbs:
The LC MF cutting pad is way more aggressive than the LC Orange pad. The MF pad is also more aggressive than the Hybrid Orange. Simply put, the MF pad will be more aggressive than any foam pad.
I've got a PC 7424XP and planning to start with Meg's UC.
I was going to test spot with a LC Hybrid White first, but I have a feeling that I will need to go more aggressive.
I just didn't know which of the three above would be the next logical step.
I'm working on correction for a black Sport Trac. Paint still has decent gloss to it and CC intact, but FILLED with spider webs and swirls from improper washing. Several RIDS also, but just looking to minimize rather than remove since it is a DD.
I've got a PC 7424XP and planning to start with Meg's UC. I was going to test spot with a LC Hybrid White first, but I have a feeling that I will need to go more aggressive. I just didn't know which of the three above would be the next logical step.
When I see aggressiveness, I think of the amount of *cut*. You're right, the MF pads have more ability to cut compared to the LC orange pad. MF pads can also finish very well for the amount of cut they can provide, as you stated.I would say the microfiber pads have the ability to be more aggressive than foam cutting pads.
Keep in mind, you can finish out with MF pads, just look at the Meguiar's DA Microfiber Correction System.
[ame=http://www.youtube.com/watch?v=WhJYFLgIjhE&hd=1]Meguiars Microfiber DA Correction System - YouTube[/video]
I'm not sure you would want to finish out with a foam cutting pad? :dunno:
How aggressive or how NON-aggressive they are depends upon the liquid you're using with them...
:xyxthumbs:
