statusdetailing
- May 15, 2012
- 1,325
"By creating a polish that doesn’t have any oils, waxes, silicones, polymers or fillers, you can apply a paint coating immediately after polishing your paint with Detailer’s Coating Prep Polish. There is no need to chemically strip the paint using isopropyl alcohol or volatile wax and oil removers.
This is an excerpt taken from the DP prep polish page.
So if I use opti-eraser shouldn't the surface be clean enough for the coating?
I get that. It makes sense if your paint is in awesome shape and only needs very light polishing. But, like other guys have already mentioned, if you've already done a ton of cleaning, claying, polishing and an IPA wipe, the paint should technically be laser clean, wouldn't the BL paint coating bond without the cleansing polish? In my mind it should bond unless, like somebody else mentioned, there is some type of catalyst or chemical reaction with the prep polishes.
