Over spray
badhemi
i'm doing a detail on a show truck and noticed over spray on the whole truck. i've clay bar'd the truck three times and that got about half of it off. i'm using XMT #2 because the swirls and scratches aren't that bad. question is is there anyway to get the rest of the over spray off short of using a rotory buffer(which i don't have and have never used before). thanks for the input
You may have to go to a more aggressive clay...the mild clays will not get all overspray off...now a more agressive clay will cause some marring also...sometimes a polishing will get the overspray..but it depends on the adhesion of the overspray...if its on good the polish may just burnish it to a point....3M..Megs and Claymagik and AG sell a more agressive clay for body shop type use...it will remove the over spray..but you will have to polish out the marring it may create....
AL
It really depends on the type of overspray that's on there. On most overspray jobs I do where lacquer thinner or clay doesn't cut through it quick, I'll step up to a 4000 grit sandpaper. If you go this route, you'll most likely be required to use a light polish AND a rotary. So, I really think you're at a fork in the road. In addition, it's not wise to use a rotary in itself (with product) to remove overspray/contaminants. You need a clean surface prior to buffing or you'll induce unnecessary swirling and/or marring from the contaminants being trapped in the pad while they are being removed.
well i think i'll give the owner the "bad" news. on the third clay i used a fairly agressive clay thats why i'm polishing with the XMT #2 because of the maring. i plan on getting a rotory but until i get some practice with one on some wrecked finders and hoods i won't be using one. thanks for the feedback.
