Ozone Generator/Machine
98LowRanger
Looking to take my interior cleaning to the next level with the help of a small ozone machine to eliminate odors. Now I realize that a thorough interior cleaning is still needed before using the ozone machine. I don't know what to look for or where to start because there are soooo many different makes and models that are priced from $40 to $1000! I can tell you that my budget is in the $100-$200 range so I hope a good ozone machine can be purchased for that. My top choices were models by Enerzen, Fresher Air, and New Comfort. If anyone has experience with those brands please let me know.
I have the $99 one from Amazon. I use it for my house, not detailing. It's not the fanciest, but it really pumps out the ozone.
It doesn't smell exactly like fresh air, more like "synthetic" fresh air, if that makes sense.
If you make money off detailing, I'd get a nicer one, but otherwise, I think all of them in that price range are pretty similar.
save your money.
Bought one 4 years ago,useless as the smells and odors just come back have to target the area and clean it otherwise.
Odor bombs work great for a nasty smelling car ,usually takes 2 of them.
Like most things, it takes a multi-faceted approach.
Of course it won't work if you don't actually remove the source of an odor.
Save your $$ and spray this into the vents. Smell is very very strong for a few weeks and then it's perfection. Works great.
3D HD Odor Eliminator
This option is very tempting. At $9 a can, it won't take long to add up though. Yes, I realize I would have to buy 22 cans to equal the $200 I am looking at spending on an ozone generator, but none the less it still will add up. I don't want to mask an odor and some people are sensitive to the strong fragrances used in some of these products. I know Renny Doyle, uses Ozone (or at least he did in 2009) and he has years of experience and highly regarded as one of the best in our industry. I'm not saying, if he told me to jump off a bridge I would, but I figure that his experience is worth taking into consideration.
I watched some of his videos on ozone on Youtube which were very informative. He recommends a UV ozone generator, but there are still soooo many different brands. I'm waiting to hear back from him on which brand(s) he recommends, but due to how busy he is, I m not expecting to get a reply.
Usually owning a ozone machine owners and operators utilize them as part as income stream.If you are gonna buy one and stick it in the car pro bono as part as a interior detail save your money.If you are charging per hour or less using this machine you will have to market that to your customers for added income.
And be careful and knowledgeable about the use of one,as you can damage a car interior.
We have and use a corona discharge ozone machine at my shop, it works great but like anything, it's not a miracle machine. Cleaning first is important.
Would you mind sharing the model or at least the brand of the ozone generator your shop uses?
I used the Maxblaster for the past several years. At first I was skeptical and really hesitant about the purchase. I researched several brands and really had my doubts, but ordered one anyway. I do detailing of Mike Brown Ford Subaru on their really bad trade ins and was doing a to of vehicles with heavy smoke smell. The Ozone generator really does work. It is no substitute for a really good cleaning of the interior, but the results have been great, much to my surprise. A couple weeks ago I got a trade in that had been smoked as probably every time the doors were open. It was so bad that the head liner was grey after it was cleaned, did not know it at first, and after spraying APC on the interior surfaces you could actually take your fingers and feel ridges where the APC had run down. I cleaned the interior really good with a Tornado and hot water extracted the seats, which changed back colors again to grey. It still had a strong smoke smell and I used the Ozone Generator for longer than normal and amazingly the vehicle was sold a couple weeks later and had no smoke smell at all. Without a really good cleaning it does not work as well but I am sold on it and use it a lot. Hope that helped a little.
FYI check out the health hazards in using ozone generators. Not something you want to be breathing on a regular basis. I use one in rental properties occasionally but open up the home for fresh air after use. They do work however...
Thanks for the info!! They are actually one of the main brands I was looking at buying.
UV ozone generators seem to be the way to go, but sadly most decent ones tend to be selling in the $400 range. I have already spent too much on detailing supplies this year so it may have to wait till next season.
This is something im looking into as well. How are you all charging for it?
Sent from my LG-LS720 using Tapatalk
Tree
Not sure I will be of much help on answering your question as I am not using one...Yet. I don't think an "Ozone generator service" will be an easy sell on it's own. Even though there are benefits to using it when no odor is present. When a customer specifically mentions an interior order is when the ozone will really be beneficial (after a thorough interior cleaning of course). So I guess whatever you charge for a thorough interior cleaning or spot removal if you know the source of the odor and then add what you think is reasonable for ozone service. The machine does all the work and it only takes 30 minutes to 2 hours generally for a whole interior. So labor isn't really a factor, but cost of the machine needs to be. It's definitely not a machine the average person owns and if it completely rids that last bit of lingering odor while sanitizing the interior cabin, the added expense would be worth it. That's the way I look at it anyway.
Can you explain further?
If you over generate the car or leave it running too long you can turn the interior a whitish color. Not sure how long you would have to leave it running to do that, because I've never saw anything damaged at all with the one I use. I normally start out around 20 to 30 minutes and if that does not take care of the odor then I will try it again in a day or so. The odor may not be gone completely at first but leaving the windows open and letting air inside the car makes the smell go away. As long as you use common since and follow the instructions for the size of the ara you should be fine.
