Ozone Generator/Machine
Can you explain further?
This is something im looking into as well. How are you all charging for it?
Sent from my LG-LS720 using Tapatalk
I normally charge the same fee for an interior cleaning depending on what all the interior needs and then I add a $50 upcharge for the Ozone Generator use. It normally takes about 20 to 30 minutes of just hooking the machine up letting it do it's thing. No work to it at all. You leave the car running and the AC on to circulate the air through the vents, roll the windows up and let it work. You will then turn it off and roll the windows down and let it set. After it airs out it is normally fine.
