Pads/Backing Plates/etc for boat gelcoat detail? Small areas
Speez
Browsed around quite a bit but haven't found the definitive "guide" I'm looking for I guess. Living in the city after college I've been out of the game for awhile, but I have my PC DA and all of my auto detail stuff back home. We need to do a compound/polish (hoping no wet sand) polish on the hull of our family boat, so I've picked up some 3m wool pads and so w meguiars and Marine 31 compounds and polishes to try.
What I'm trying to figure out is what smaller pads to get and more importantly, what backing plates go with what size pad. There are some areas of the transom obscured by grab handles and cleats that I would rather not remove, so I think an extension and some 1-4" range pads are I. Order, but for the life of me I cannot get a good handle on what pad goes with what backing plates (I swear every manufacturer is a mess, even finding the right plate for the 3m pads for the rotary was a nightmare.)
I've been looking at the lake country hybrid or wool pads, can anyone confirm what works right/well with what? I've found the 3" and 6" extension kit, but it appears lake country has like 2.5" backing plates, 2 7/8", 2 3/4", 3", etc seems all over the place. Any direction on what combo works well for those tight spots would be appreciated.
Sent from my Pixel 2 XL using Tapatalk
I could be wrong, but my understanding is the foam pads are not going to cut it (literally) for the gelcoat work and I'll specifically need wool (hence the few 8" 3m pads). Trying to figure out which sized back plate works correctly with which sized pad. The fact that every pad description doesn't state "accepts x.xx" backing plate" is kinda crazy to me.
Ya I agree with you that the size of the pad face and the velcro should be stated in the description when buying it.
What I could found from the descriptions this is the LC backing for rotary threads and 3.5" spot buffs pads and 4" wool pad. It's so you get a little safety zone from the backing plate to the edge of the pad. Hydrotech and ccs pads and flat pads. Look for the ones that are thicker foam and not the thin pads that are popular on the DA. Electricfied wool pad 4" and 3.5" purple foam wool pad for wool if going with LC pads. Maybe some others chaim in on what they use on boats gelcoat.
Rotary 2 7/8 inch Flexible Backing Plate, backing plates, back plate, lake country backing pad
Electrified sheepskin wool compounding pad, spot buff wool pad, 4 inch wool buffing pad, lake country wool pad
Foamed Wool 3.5 inch Buffing/Polishing Pad, spot polish with Lake Country Foamed Wool Pad, wool buffing pad, small wool pad
Will the the wool pads be good enough. I started last fall,doing test areas, on our Cobalt 242 and wool was not good enough. I hit with wet sanding, then wool, then compound, then polish; and that worked. Now to finish the boat this spring. Mike Phillips has a great book here on stages of repair n what to use, I suggest starting with that. I missed his class this year as I was on business trip to China.
I'd recommend getting the Lake Country Rotary Buffer Extension Kit and some small wool pads.
The Cyclo Wool pads work fine on the rotary and both Buff & Shine and Lake Country make 3.5" wool pads.
If I'm' going to CUT I tend to prefer a real wool pad, not a fluffy wool pad light duty wool pad. Here's some pictures showing the FLEX PE14 at work on a console. The compact size allowed the guys to get into tight places. Extension would help too. A full size rotary won't do this type of surgical work.
Robert Diterlizzi is using the Flex PE14 Lightweight, Compact Rotary Polisher with the 3" PFW thin pads to knock out the intricate areas and tight spots on the console.
A full size rotary buffer couldn't do this...
This is Rick's first time to one of our boat detailing classes and Rick wanted to learn how to use a rotary buffer, so I matched him up with Robert for some expert one-on-one training.
Robert and Rick making gel-coat shine!
More pictures here,
16' Key Largo Center Console Boat Detailing Class with Marine 31
There ya go, Speez, right there from The Master himself.
