Pads for Griot's Random Orbital Polisher
RandyD
Can I use a 5" or 5 1/2" pad on the backing plate that comes with it or do I need a 6".
Thanks
Hey Randy,
I think it would be wise to add a smaller backing plate to your arsenal for pads of this size - otherwise you run the risk of "whacking" (technical term) stuff with the backing plate that is larger than the pad.
I have the Griot's and got two smaller backing plates - no regrets...:xyxthumbs:
Thanks. Any particular backing plates you recommend?
I got the Lake Country 3.5" and 5" plates for mine - they work great!
x2 To the OP: It is recommended to match the backing plate to the pads you will be using. Lake Country pads and Lake Country backing plate.
