•Cons (DIY):
1.) Initial purchase price {You want how much for those few mLs?!?!}
2.) Seemingly an unending, and always differing array of methods/processes involved in "Prep Work".
3.) Application can be nearly as involved as #2 above.
4.) "Bonding" (?)
5.) Total cure-time: Variations on recommendations abound!
•Cons (When you're hiring a Professional):
1.) You want how much to prep, and then apply a Coating to my vehicle?!?!![]()
(Just following manufacturers' retail price suggestions :dunno
•I hope to get back with the "Pros of Coatings", anon.
If you don't mind...I'd rather refocus and ask:Wow, Bob. Have you had bad luck with coatings?
Were there any: "wants-of-veracity"...to what I listed?
•Cons (DIY):
4.) "Bonding" (?)
2.) The amount of prep work needed to apply a coating is not as involved as some make it out to be. The initial prep for a coating is no different than the prep one should do before applying wax or sealant. Wash, iron-x, clay, and polish if you want a nice clear base. The only difference there would be a quick wipe down with eraser which translates to about $2-$3 of product per vehicle.
Well sure, there is a learning curve to proper application of a coating
Here's a couple of recent examples (including yours)...(there are OH! so many, many more---Most have read/seen them):•Cons (DIY):
The above could almost throw me for a loss.If will be coating, follow the coating's instructions. For OC 2.0, you would need to remove any residual LSP (using a DA, if necessary), wash thoroughly with Dawn or APC (likely 2x), and then an IPA wipedown. You could clay first, if need be, especially if you'll be using a DA to remove the existing LSP.
At that point, the finish should be "naked," which is what's required for OC to bond. Definitely do not use a pre-wax; many of those have fillers which you definitely don't want on the vehicle.
