Eldorado2k
- Nov 9, 2015
- 14,583
- 730
I iron decon 1st. Then rinse, wash, clay, etc.
Unfortunately clay will not remove iron fallout. It will "shave" the tops of it but the imbedded parts will still be in the paint. Get yourself any iron remover as they all do the same thing. It won't melt off your paint. Just keep it away from plastics like the cowl to avoid the potential to stain.
Can't speak for those other products as I have not used those for claying.
Will the iron remover still work pre coating removal?If you plan to polish no need to focus on "stripping" anything off. An abrasive polish plus the mechanical action of the polisher will do the work for you. Also the cut of the pad. You could always add a little APC into your wash if you want to increase its cleaning ability.
The paint is white. Don't expect it to pop like a dark colored paint. White will appear brighter and in the right light it will be glossy. Any polish will achieve that. The questions is are you ready to step into the realm of a true coating or stick with a sealant or wax. There are pros ad cos to each product. So what are you really looking for here?
The question is, should i add in a step of polish with m205 on a yellow pad after the clay, or will the essence handle any of the clay marring with the yellow pad?
In terms of what i want for the rest of the summer, I want aesthetic more than anything. In the fall i will run a strip wash, some Gyeon surface prep, and apply the Griots ceramic coating in 2-3 layers, and ill maintain that with the ceramic wash and coat throughout the winter.
Essence will remove it. The test spot will let you know.
Yes it will. Keep in mind that griot's 3 in 1 ceramic spray or whatever it is called is not a true coating. It is a silica spray sealant and there is no benefit doing multiple layers.
I was mistaken as to posting pics to one of your threads. It was another member with a white car asking how to make it pop.
All of these vehicles were polished with Essence and coated with UK3.0
IMO, for white cars they do have a glow after this combo and the best thing is all you have to do to maintain them is wash them.
