Thanks for your help guys. I'm gonna try and polish it and put some wax on it tomorrow. I'm pretty sure that the hood IS single stage, but I think the rest of the car is clearcoated,
Completely possible the hood has different paint than the rest of the car...
Real simple test... take some AIO, which is a Cleaner/Wax or Cleaner/Sealant for the D.O., and rub some on the hood with a white cloth and then turn the cloth over and look at it.
If you see gobs of red pigment coming off you're working on a single stage paint, if you see the color of the AIO and the cloth then you're working on a basecoat/clearcoat.
If you're working on a bc/cc then that paint has failed... and it's past the point of no return...
If it's a single stage paint and it's turning white after you polish it with the AIO then there's a chance you might be able to save it with a pure polish from the old days... like #7 Show Car Glaze from Meguiar's.
Something about the "oil base" used in #7 that can work miracles on single stage paint. You can find these same oils in #3, #5, #9, #81, #45, and Deep Crystal Polish, if it is single stage, get your hands on one of the above, and rub out half the hood with it and see what it does for the color.
THEN... allow a few days to go by and see what happens... if polishing with a pure polish restores the color BUT the results don't last over time, then the paint has become "Unstable".
Once a single stage paint becomes unstable it's past the point of no return.
Yes i know that .....Jeff used the Klasse AIO and it is an acrylic sealant and polish
Correct, it's a cleaner/sealant, in the normal world the term Cleaner/Wax is generic name for a category for paint protectant that also clean and even abrade the paint, this features dramatically separates them from finishing waxes or show car waxes like Souveran Paste Wax which has no cleaning ability.
What Klasse AIO doesn't have are they polishing oils like the #7 has which are unique to Meguiar's, (to my knowledge).
These oils penetrate into single stage paints and restore and revitalize the color. A product that primarily cleans and protects, but is missing these oils, won't have the same effect on a single stage paint.
Well time will tell after Jeff polishes it . The single stage reds in particular are prone to oxidize to point of no return.
Ditto
But hey i really WANT to be wrong about this and maybe i am
Ditto...
I never like telling someone their paint is past the point of no return...
