paint sealant for glass?
I was up in Maine today and just got back......Thank you Corey!! :props:
I hope you had a wonderful trip buddy!! :props:
I avoid BFWD on glass. I had a problem using it. Once the windows got dirty and I used a strong glass cleaner on them, there was an unusual amount of oil on them once I started cleaning them that just pushed around a lot. It was tough to get the windows clear with 1 or 2 applications. After that I really began to understand the difference between paint sealants and glass sealants. True glass sealants I noticed are not oily (like bfwd) and usually have really strong drying agents to make them bond hard and dry (which is why they smell of solvent really badly).
Very interesting Mike! I've learned something new. :props: Thank you :cheers:
Sure, what do I see just AFTER doing all the glass with BFWD.... It will be a good experiment
though.
BFWD was so impressive on the paint that I had to try it. Did all the glass EXCEPT winshield and it turned out so good--did the windshield today.
Sort of copied the paint routine:
- washed real good--- with Stoner's Invisible Glass.
- used Meg #205 for least aggressive approach and tried out the Pinn Polishing Pad
(hard base for 3.5" pad to use by hand). Deep deep cleaning if nothing else. That actually worked pretty good with white pad on small job instead of breaking out the big gun (Flex)
- then applied BFWetDiamond with red pad by hand. On glass you could really see the product and applied it microscopic thin. In fact, wondered if that was even enough as it almost disappeared as I applied. It seemed to cure out well overnight and (so far) looks/feels
great.
I'm hoping it lasts better than your experience---what strong glass cleaning product did you use? I'll try to avoid that one :)
I'll report back as some time goes by.
Since I tried Aquapel, I've migrated away from using either product. Aquapel was designed for use on glass therefore it lasts for 5 to 6 solid months through a long hard New England winter. :props:
BobbyG..we have the same sh..y weather, so if it works for you, I'm trying it!
Yes I do! In fact, each application contains enough product to treat the windshield and side windows...
After giving the windshield a thorough washing, I apply Aquapel to it by following the simple directions included with the product. It has a relatively strong acetic acid odor so don't up it up to your nose once you snap the case releasing the product into the applicator pad...
I used Aquapel yesterday...I agree with Bobby on not breathing this stuff in...accidentally got a deep breath if it yesterday WOW...nasty stuff.
I do have a question. The directions say not to let the product dry on your windshield...this stuff starts flashing immediately. Is it like opti-coat where you have a couple minutes to knock down high spots or it will haze?? I got a nice clear finish...just hoping I didn't wipe it too soon.
Interested in this as well. Planning on sealing my windshield with aquapel after I polish it.
Did you use a paper towel to knock down the high spots or a MF towel?
I used a paper towel like it said on the directions that came with the product. The folded up paper towel works fine. I cleaned the windows three times before I applied it. I checked for streaks with the brinkman light just to make sure it was good. There was enough to do the windshield and two front windows. I guess this depends on the size of the windshield. I did the windshield in halves. I did half then buffed real quickly...then the same on the other half...then one front window at a time. I would find out if you can leave it on there for a minute before buffing before you apply it...it may make it a little easier for you. It wasn't really a problem...just had to work really fast and as I mentioned I may have taken off product that wasn't supposed to come off. Hopefully someone who is a little more familiar with the product will chime in.
I have tried various things on glass, waxes etc were all ok'ish on side windows but not that successful on the windscreen. For many years I used Aquapell and liked the way it work but for the last couple of years I have been using Gtech G1 on all the glass. The G1 tends to last on my car about a year, some get much longer. I would like to try the G5 on the side and rear glass but it has been a tough year financially.
Despite the financial constraints I would still buy G1 as it is an aid to safety plus I have not used a glass cleaner in several years as the G1 is very easy to clean
One other advantage of G1 is it does make scraping ice off the glass easier, not by a huge amount but definitely easier
There are probably similar performing products for sale which I am not aware of but for safety and ease of cleaning, I would suggest a dedicated glass sealant is a great idea
:iagree:G1 for the front screen and G5 for the back and sides.
