Paint thickness gauge
Gcleov
Hello
Found this on ebay.. can i consider it to be usefull for detailing or is too inaccurate??
Digital LCD display
Data HOLD function
Zero calibration
Comes with iron base and non-iron (aluminunm) base
Portable, user friendly and easy to carry even in pocket
Low battery indication
Auto shut-off if no operation in 1 minute
Target Measure: Non-metal coating thickness on the metal surface
Measuring Range: 0~1.25mm nonmetal coating on metal surface
Precision Measurement: 2% RDG 0.02mm [2% RDG ±1mil (steel and aluminum only)]
Power Supply: 1 x 3V CR2032 button battery
Working Current: <10mA
Auto Power off time: No actions in 1 min if leave the measured object
Minimum base diameter: 10mm
Critical base thickness: 0.5mm
Display resolution: 0.02mm/1mil
Operating Environment
Temperature: -5~40°C
Humidity: 5~95%RH non condensing
Storage Environment
Temperature: -20~60°C
Humidity: <85%RH (without battery)
Dimensions: 80 x 42 x 24mm
Weight: approx. 36g (without battery)
1 x Mini Thickness Meter
1 x 3V CR2032 Battery (FREE)
1 x Iron Base
1 x Aluminum Base
English Quick Start Guide
