SNP209
Active member
- Sep 26, 2016
- 961
- 247
I certainly do.
The lines are so helpful, a tiniest dent is visible under the light.
For this particular dent (pictured) I thought I can do it from behind, but there is another layer of metal on the inside, so has to be glue pull.
As you know the surface has to be cleaned with alcohol so the hot glue sticks as it should. Also, to remove the glue, alcohol is needed again. My issue is that the car has ceramic coat, so alcohol is no, no I believe .. ?!?
If you're lucky you can find an access point between the two layers and push the metal but that is if you have the right rod to begin with. Using alcohol on a coating is fine. Most prep sprays are alcohol based anyways. Glue pulling on ceramic coated cars is tricky. With most quality coatings, the glue simply will not form a strong enough bond to pull out the dent and will need to be removed for a proper pull. A good way to test this is to place your tab on the dent and once it has enough time to set try to pull it with your hand. If it comes right off, then you definitely need to remove the coating. If it doesn't, then try to pull it with whatever pulling tool you have, gently. What you will be looking for is movement within the metal. If the tab pops off before you see any movement, then the coating will need to be removed or "knocked down" at the very least. It doesn't have to be the entire panel, just the area where you need the glue to bond.
