Paintwork cleansing lotion with DA?
Can you use the pinnacle paintwork cleansing lotion with a DA?
Yes.
_________________________________________________
•Machine Application
(For easy application for novices or pros, use a Porter Cable 7424XP dual action polisher.)
-Buff away Paintwork Cleansing Lotion with a soft Cobra Microfiber Towel. Flip the towel often as you buff.
-Wash the vehicle and towel dry.
-Mist a white polishing pad with Crystal Mist Detail Spray to allow easier application. Pour a circle of Paintwork Cleansing Lotion on the pad.
-With the machine turned off, spread the lotion over a small area.
-Set the max speed at 4.5 or 5 and turn the machine on.
-Polish in a figure-eight pattern until the lotion begins to dry or disappear.
-Buff with a clean microfiber towel.
-Continue to the next section until you’ve polished the entire vehicle.
•Always follow Paintwork Cleansing Lotion with a coat of wax.
-Souveren or Signature Series II will give your vehicle a glossy,
wet-looking shine.
•Notes:
-For best results, apply Paintwork Cleansing Lotion out of direct sunlight. Do not apply to hot body panels.
-Paintwork Cleansing Lotion is not designed for use with
high speed rotary polishers.
Any cleaner polish where deep cleaning is preferred, a machine will always be the preferred method of application. You're not just spreading it out like a wax...you are working it into the paint. Its a great product.
the DA is going to give you consistent and better results much more than your hands ever will and it never gets tired. let the machine do all the work for you...
Thanks! This is great info.
Is the difference between this and the Advanced swirl remover the fact that advanced swirl remover has a slight abrasive and deep cleansing lotion does not?
These two products are like comparing apples and oranges. They are very different.
The Pinnacle Advanced Swirl Remover is a medium cut polish. It's more aggressive than the Advanced Finishing Polish but less aggressive than the Advanced Compound.
The Pinnacle Paintwork Cleansing Lotion is a non-abrasive, chemical only paint cleaner. It will not remove swirls and scratches it will clean the surface of the paint from light oxidation, staining and surface impurities.
And "yes" like most paint care products, best results come from machine application but only use soft polishing or soft finishing pads and medium speeds when using any paint cleaner by machine.
And in my book... I always do a Test Spot first anytime I'm working on a car I've never worked on before and/or applying a product to a car that I've never used on the car before.
How To Do a Test Spot
:xyxthumbs:
Great info from Mike! Silverfox nailed my technique for PPCL in that i work it with my PC on and into the paint and with maybe a white LC pad for harder clears and black or blue LC pads for softer clears. I LOVE that product before applying a compatible sealant. Another product i "rediscovered" is P21S Gloss Enhancing Paintwork Cleanser. I used it way back in the day and after going through some old product inventory decided to polish off (pun intended) my remaining product.
Both of these products along with a whole host of others work to effectively clean your paint very well and work so much better by machine.
Sorry ,but I have another question:) can I use the Pinnackle cleansing with the Rupees buffer and like yellow pad ? I got my first job after the boot camp :) Yehaaaaaa:) and it brand new BMW X5 no swirl marks and nothing ,just the owner wants to make it shiny and preserve the paint.
Any suggestions would be greatly appreciated!!
Thank you in advance!!!
Me? I'd use the Rupes polisher with the RUPES white foam finishing pad and the Rupes Diamond polish if I was using the "Rupes System" to prep a swirl free BMW for sealing.
But if you wanted to use the Pinnacle Paintwork Cleansing Lotion then I'd recommend sticking with the Rupes White Ultra Soft Finishing pad.
Keep things simple...
Understood :) as always very useful information, thank you very much !!
You are right ,keep things simple ,that's what we cling to do :)
Thank you Mike so much !!!!
If you don't have a Rupes White pad another companies non agressive pad will do an excellent job also.
