Paste wax on machine
joche26
How do you apply paste wax on a foam pad for a machine?
put the cake on a rag and rub it on the pad or rub the pad on the wax then put it on the buffer. Lot of ways
I use a little mellon ballers sometimes scoop out a little ball, then use that to rub on the pad.....
Close the lid tight and bang it against something hard (wall) to loosen the side walls, then grab a microfiber glove and hold onto the paste puck, hold the puck against the DA pad and depress the machine on a couple of times on and off real quick, and then spread it onto the panel, repeat when you no longer see any more wax being spread onto the paint
This video at 4:22
[ame=http://www.youtube.com/watch?v=PWdYCHZrpd8]How To Remove Oxidation by Machine Polishing with Mike Phillips on Motorhead Garage - YouTube[/video]
I use a little melon ballers sometimes scoop out a little ball, then use that to rub on the pad.....
:laughing:... I've done that before. It was a quick wash and wax so the customer was hanging out. He looked at me like I was a nut when I whipped out a small melon baller and dipped into the tub!
