maddenbowler
- Jun 3, 2008
- 203
Dont have time for a full detail but want to freshen my car up a little. Should I apply my poorboys sealant before or after the Black Hole Glaze?
Usually you put the glaze underneath the sealant so that the sealant will cover up the glaze and extend its durability.
I was under the impression that you did it vice-versa..... seal, then glaze.![]()
You can do that for temporary looks. Personally, I never seal over a glaze. If I have a sealant, I will glaze on top of it and then put a nuba on.
Hmmm, OK. So..... Polish, Finishing Polish, Glaze, Seal and then Wax ?
I was instructed to seal then glaze in the past![]()
Hey Ryan,You can do that for temporary looks. Personally, I never seal over a glaze. If I have a sealant, I will glaze on top of it and then put a nuba on.
Hey Ryan,
I was reading your reply post concerning the PB BLACK HOLE GAZE. in it you indicated that you applied the gaze between the sealant and the nuba. I have just waxed my car and discovered some very fine swirls on the hood. Could I apply the glaze over the Fuzion wax that I have applied and than top it off with another coat of the fuzion?
Thanks in advance for your or any one elses reply.
Stu
I guess I am STILL confused. Can I use PB Black Hole on top of an existing LSP, then top it with either a sealant or a wax?
I think the argument will be that once you glaze....you loose the sealant or wax that you previously put down. I think that's what I've read. Can anyone co-sign on that?
