PB Polish with sealant
Yes, it's an AIO. I just used it and liked the results.
I was unaware that AIO type products are synonymous with fillers.
Most AIO will have at least some degree of fill. Some more than others but it is actually a good thing since when using one you aren't looking for perfection anyway.
Sent from my SAMSUNG-SM-G900A using AG Online
I am not sure if PWS has filler or not. It's a great AIO that is great for one step clean ups.
If you read the package, it says if used by hand it will act as a glaze. This usually indicates it is cleaning and filling. This product does have some abrasives, slightly more than most cleaner waxes, but not too potent. If you want some decent cut, use with a heavy polishing, or light cutting pad with a DA. I usually top this with a coat of Collinite 845. This is my favorite AIO. It will not stain trim, easy on and off.
Thank you all for your input. I did read the description on the bottle and online and thought as you mentioned it must have some fillers if they're indicating can be used as a glaze.
What prompted the question is that I was so impressed with the results when using with a white polishing pad.
