Busy mind
- Dec 1, 2014
- 244
I have an interesting problem on a long term project car for a customer. I used PBL original coating on it after several weeks of correction off and on. I worked on it in between my other projects so I ended up coating a couple panels at a time.
At any rate, I used the booster on the car a few hours prior to the customer coming in to put his decals on the car door. Long story short, his decals would not stick. At first I thought it was because of the booster, but I remembered that I had trouble taping off a panel which I already coated and had cured for a few days.
Should I wash the car and see if that helps? I don't have much more time to put into this car and I have other cars stacking up, so Id like to find a solution and send this one out the doors ASAP.
Thanks for your educated suggestions.
