Pc Kit?
DjbuddyPL
I always waxed my cars by hand, got good results and all, but after luring around here for months i just cant compete with the results i see here that are done with a pc. Since i never used one, i have few questions. I want to get one of them kits that come with the pc, back plate, pads and some waxes,sealents, polishes ect... How long do pads last, do i use one pad to polish the whole car? I have a dark colored car, which kit would be best for me. Paint is in decent shape, with few swirls, few etched water spots and fine scratches in the clear coat. Also which products would suit my needs best?
what are the life spans of pads. Do i throw them out after each use, or can i do the cleaning on the fly method and use one pad to polish the whole car?
Where do you live? Maybe a fellow Autogeeker can invite you over for a demo.
Even with cleaning on the fly you will need multiple pads. You can clean your pads after your car is finished and continue to use them over and over.
since i will be apply wax by hand, all i need is a light cutting pad right? So i should use like 2 or 3 pads for the car for polishing it?
There are so many factors to consider that it hard to give a definitive answer. Many people use a test section to figure out how to approach the rest of the car.
If you plan on using a 1 stepper, you could get away with 3 pads.I have done a 1 stepper for people and they were blown away by the results. I thought the results were bad. So what you are expecting is a factor.
Another factor is the hardness of your clearcoat and the severity of the imperfections...
I think Harrisburg is about 60 miles from me. If you would like to make the trip, I would be more than happy to help.
The paint is in pretty good shape, it only has swirls that can be only seen in direct sunlight, and very few water spots that also can only be seen in the direct sunlight. I was watching the videos in the link posted above, now do i have to do all the same steps as he did, or can i just use the swirl mark remover then go straight to applying wax, or the other two steps are a most?
For the most part an aggressive product like a swirl remover does not leave the paint LSP ready. (LSP=Last Step Product, such as a wax.) It generally needs to be followed by a less aggressive polish first to bring out the shine and remove any possible micro-marring caused by the more aggressive polish. You can achieve pretty good results with a 1 step product like Menzerna Power Finish PO 203.
32 oz Menzerna Power Finish PO 203, one step polish, swirl remover, finishing polish, car polish, german car polish, menzerna polishing compounds, power
16 oz Menzerna Power Finish PO 203, one step polish, swirl remover, finishing polish, car polish, german car polish, menzerna polishing compounds, power
If your paint is in pretty good shape, this might be the way to go.
If you are not already, claying your car is important also.
So am i better off just buying things separetly, or stick to a kit? im not trying to spend alot of money trying to keep the price as low as possible. So what things are essential to buy? like
1. Pc
2. How many pads and which ones?
3. Which one stepper would be best and not expensive?
4. Which wax for dark colored car, or should i stick to my NXT 2.0
5.What else do i need?
1. Pc
How much are you looking to spend?
Are you already using proper washing techniques? Like two buckets with grit guards? Have a good wash mitt?
Do you have microfiber towels?
Are you claying?
Once i get all this order, im also picking up mother clay bar kit, for washing i use a foam gun to then wash with car sponges, and i do have alot of microfiber towels? I would like to keep everything under $220-250 if possible?
PCXP 7424
Porter cable 7424xp, 7424xp, Porter Cable 7424XP Dual Action Polisher, Porter Cable polisher, car polisher, buffer, sander-polisher
5" Backing Plate
lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
3 Pack 5.5" White Pads (scroll down for 3 pack, slightly cheaper)
CCS foam buffing pads,foam polishing pads,lake country foam pads,foam polisher pads,buffer pads,lake county pads,porter cable pads,pads for air sander
Mother's Clay Bar Kit
Mothers California Gold Clay Bar - Mothers California Gold Clay Bar Paint Saving System, detailing clay bar, 2 clay bars
Don't forget to add a free sample!
I recommend Wolfgang Deep Gloss Paint Sealant.
Free Sample with your Order
Use up that NXT before you worry about your next wax. Give you time to do some research. There are tons of great waxes and sealants.
When you check out use the code AGO for free shipping.
Total price $220.
Hope this helps.
Almost forgot:
From now through Sunday at midnight Sept 19th. (EST), every order placed at Autogeek.net valued at $150 or more will receive a free Autogeek 5 Gallon Wash Bucket with a Grit Guard Insert, plus a 32 oz. DP Rinseless Wash & Gloss and a White/Yellow ShMitt . That's a value of $48.97, yours just for placing an order of $150. And don't you need some new detailing products anyway? Autogeek.net has new Poorboy's World products, new Optimum Opti Clean, and you have to try Dr. ColorChip. Now is a great time to order!
When you place your $150 order, please type in the comment box at checkout: BUCKET. This offer is only available through Sunday, September 19, 2010 and it's only available to forum members!
AND
This is a limited time and limited quantity offer that starts right now and ends once our extra supply is gone!
Place an order of $50 or more at Autogeek.net and enter a note in the Comments Box that says:
Dwayne, please include FREE Poorboys SSR 2.5 Swirl Remover!
For orders that are $50.00 or more, you will receive a free 16oz bottle of Poorboys SSR 2.5
For orders that are $100.00 or more, you will receive a free 32oz bottle of Poorboys SSR 2.5
