PC7424 vs Meguiars G220
ercapoccia
Hi guy, here in europe it's pretty hard to find porter cable products so i'm looking for a valid alternative available in my continent.
I was wondering, is the Meguiars G220 as good as the PC7424? How can i chose a valid polisher machine?
As far as I know you should be fine as it is a comparable machine backed by a solid company. It does have more power than a 7424
The Meguiars polisher should work well, the specs are pretty comparable
I have the american version,G100?, and it worked fine. Though mine broke Megs does have a lifetime warrenty and it sounds like they stand behind it. It worked well with the 5 inch pads at any speed and the carrying case is pretty sturdy.
What's about the Kestrel DAS-6 Dual Action Polisher?
It is cost 2/3 of G220.
New from Kestrel, this Dual Action Polisher offers all the featuers of the more expensive machines at an affordable price.
The machine comes supplied with a UK 240v plug, is fully CE marked and has the peace of mind of a 1 year manufacturers warranty.
Dual action polishers are very popular with car enthusiasts and professionals a like as they are low risk but give much better results than polishing by hand. With a powerful 500w motor it is possible to removes scratches and swirl marks when used in conjunction with a machine polish. It is also a perfect for applying glazes, sealants and waxes.
Specifications:
* Orbit Size: 8mm
* Backing Plate Thread Size: 5/16" (same as Porter Cable, G220 and UDM's)
* Variable 6 Speed Dial: 2,500 to 6,500rpm
* Removable side handle (left or right side of machine)
* Weight - 2.3kg (approx)
* Supplied with a Velcro Backing Plate Size: 125mm ( 5” )
* Fits 5", 6" and 6.5" polsihing pads
Key Features:
* CE marked / 240v with UK plug
* Soft Touch Finish
* Aluminium Gear Housing Cover
* CNC Finished Gears
* Electricity Feedback Circuit
* 1 Year UK Manufacturer Warranty
the griots machine is supposed to be about the same as well, is that available to you....
I consider them equal ... one has a bulletproof reputation (PC) and other has a bit more power but a newcomer (Megs). Can you find the Flex locally !!
iam buying the das-6 they are very popular in europe should be good
Gosh this happens all the time and I don't know if this is the case for this thread but the title says,
PC7424 vs Meguiar's G220
There's a huge difference between a PC 7424 and a PC 7424XP
It seems it's too easy for people to not type the last 2 letters XP to clearly define which tool they're referring to?
The XP model is dramatically better at keeping a pad rotating under pressure as compared to a first generation Porter Cable 7424 and 7336
Also, is the G220 you're referring to an actual G220 or is it the new G220v2 model as there's a difference there.
Point is, if you're purchasing a DA Polisher to remove swirls you want a 2nd generation DA Polisher because it will save you time for the simple reason that the newer 2nd generation DA Polishers rotate pads better under pressure it's when the pad is rotating that it is removing swirls.
See this article, while it doesn't reference the G220 it does reference the G110v2,
How to choose the right polisher for your detailing project
Single Head - Random Orbital Polishers - Free Rotating Spindle Assemblies
Porter Cable 7424XP
4.5 AMP
500 Watt Motor
5 pounds
3 Year Limited Warranty - 1 Year Free Service - 90 Days Money Back
Griot's Garage Random Orbital Polisher
7.0 AMP
850 Watt Motor
5.5 pounds
Griot's Lifetime Warranty
Griot's Garage 3" Mini Polisher
2.0 AMP
240 Watt Motor
Meguiar's G110v2
4.2 AMP
430 Watt Motor
5 pounds
1 Year Limited Warranty
:buffing:
Interesting. I didn't know the PCXP has a bit more power than the G110v2. I thought it was the other way around.
