With the "annual" buffer sale going on I am sorely tempted to get a PC. I have a new car and at this point it only has very fine scratches in the finish from washing - no RIDS. I have clayed the car and applied Klasse AIO followed by their sealant. The finish looks great but certainly gets very fine scratches from repeated washings.
Questions:
1. Is the PC starter package the way to go? e.g., are the pads that come with it ones that I will actually end up using?
2. What polish should I purchase?
Thank you for helping me spend more money chasing the ultimate finish!
- Newbie slipping further down the steep detailing slope .................
I really don't suggest going with a starter package. But that is just my opinion. The porter cable is a solid machine, as solid as a rock from what I have heard. Let's just say, you RARELY hear people say "Stupid Porter Cable broke again". So it's definitely a good machine to start off with.
First off, what are you washing with? (mitt/soap/method?) You shouldn't be getting very many fine scratches, but you do own a Porsche and your paint is very soft (it mars/scratches easily).
In my personal opinion, I would go with 5.5" Hydrotech pads. These pads are great because they don't gum up with polish after working with them over the car. Many people like flat pads, and you can't really go wrong with CCS either, but in my experience I get better results and easier use from Lake Country Hydrotech pads. I prefer 5.5" pads over 6.5" pads because in my opinon they're easier to work with and correct faster. I also like my 3.5" backing plate with a 4" pad for the smaller and harder to reach areas around my car.
I, too, have a new car. A '09 Chevrolet Cobalt SS/TC. I had very fine swirls and scratches from the stealership washing it before I recieved it. What worked for me, and not saying it will work for you as I haven't seen any pictures, was this 2-step polishing method:
Meguiar's 205 on a Tangerine Lake Country Hydrotech Pad (5.5" and 4")
Menzerna P085rd on a Lake Country Gray Finishing Pad (5.5" and 4")
I actually didn't need the 2nd step of P085rd but I wanted it to really bump up the shine. You will probably need the 2nd step as you have very soft Porsche paint and you will likely have some micromarring from the polishing with M205 step. I would, however, suggest using the Crimson Hydrotech pads to apply the PO85rd (if you so choose to) because the PO85 is a very wet polish and you will get a long working time, great finishing results, and it won't gum up your pad with a Hydrotech pad like it will with a flat pad.
Helpful links:
lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
3.5" Dual Action Flexible Backing Plate- porter cable 7424XP hook and loop backing plate 3.5 inch.
Lake Country Hydro-Tech 5.5 x 1.25 Inch Foam Pads, hydrotech foam buffing pads, dual action foam pads
Lake Country Hydro-Tech 4 x 1.25 Inch Foam Pads, Hydro Tech Foam Buffing Pads, spot polishing pads, pads for water based polishes
Menzerna Polish PO85RD, Mernzerna 85rd, Menzerna po85rd
Meguiars Mirror Glaze #205 Ultra Finishing Polish, final polish, Meguiars polishes, car polish, 205 FP
