PCXP just arrived!
pokerbob781
Hi,
I just received my entire kit from AG and had a quick question. My PC came with the original White pad that you can screw into the PC. What is this used for? I have the 5 inch plate that I will be using with LC pads.
Thanks,
Hi,
Thanks,
That pad is junk and should not be used on your paint. I recommend tossing it in the garbage...Some will say you can use it with a MF bonnet over it, but I also do not recommend using MF bonnets...(Just my opinion)...
That's what I figured and I dont see people on here using a bonnet too often. I'll go in my box of extras I guess.
With my 5 inch backing plate, Do I use the plastic looking washer?
If this is the one you are talking about...
Yes, definitely!
You've probably already seen these but for any lurkers reading this thread...
How To Remove Swirls, Scratches and Water Spots using a PC 7424XP, Meguiar's G110v2 or Griot's Garage 6" Random Orbital Polisher
Using a DA Polisher - Part 1
[video=youtube_share;zUHRnHsSXZU]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Using a DA Polisher - Part 2
[video=youtube_share;fxwlWijdIxM]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Using a DA Polisher - Part 3
[video=youtube_share;9objUFdpsG4]- How to remove swirls, scratches and water spots using a Porter Cable DA Polisher[/video]
Most Important...
Here's how to do a "Section Pass" when trying to remove swirls, scratches and other below surface paint defects.
How to do a Section Pass
[ame=http://www.youtube.com/watch?v=Q70g83mnTn4]YouTube - How to do a "Section Pass" with a Porter Cable 7424XP[/video]
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher
:buffing:
That's exactly it.
Mike, I've watched your videos many times but I think I'll watch it one more time before I try it out for the first time.
Thanks guys,
