Looking to get the porter cable xp should i buy the standard or is the hdworrh the extra 30 bucks. Won't be using a whole lot just some mild paint correction on my own vehicles and maybe a few friends
The difference between the two is the length of the cord. If you feel you'd like a longer cord to avoid the use of an extension then opt for it....rops:
I would say if you do the work close to an outlet most of the time then the HD would probably eliminate the need for an extension cord. If you are unsure, then the extension cord may be the better choice.
