crxman2010
- Aug 25, 2011
- 295
My next project is to tear into some Harleys for minor paint correction followed by opti-coating. The first color up is Vivid Black followed by a Sedona Orange. I have a heated garage and all winter, so I am planning to remove the fenders (Front and Rear), remove the dash, seat, fuel gauge/fuel cap, and the bars to get them out of the way. I will be using a Griots 6" DA everywhere I can reach but I do not want to remove the tanks so I know there will be a couple hidden areas I won't be able to do by machine...
I do not think either is going to require much correction, but I know the vivid black has some swirls to remove just because it is so soft. I plan on using Optimum Polish II for correction, I do not think much more than that will be required. I do have Optimum Compound on hand for something more aggressive. And finish the parts with Optimum Finish Polish.
My question is pad selection and equipment. Foam or Microfiber Pad? I may be misguided but so far I am leaning to foam, particularly because of the soft vivid black and that I am not looking for quick easy swirl removal. What would you go with if your trying to get the best possible shine on the paint? (I won't be ordering any more chemicals this year as they are guaranteed to arrive frozen, so I will be working with my Optimum Polishes.)
For the foam line up I am looking at:
Crimson Lake Country Hydro-Tech 4 x 1.25 Inch Foam Pads --> Polish II
Gray CCS 4 Inch Spot Buffs Foam Pads --> Final Polish
3.5" Dual Action Flexible Backing Plate
For the microfiber line up:
Optimum 3.25" Microfiber Polishing Pad --> Polish II and Finish Polish
Which backing plate would be better, one of these or something else?
Rotary 2 7/8 inch Flexible Backing Plate
2-3/4 inch Hook & Loop Rotary Backing Plate
D.A Adapter 5/8" X 11
