Performance Chip
tybill26
This is off topic, but what is the best performance chip for gasoline engine. Have an 08 F250 with the 5.4 and research isn't telling me much. Any advice would be great. Thanks
Hello. I would say the Diablo Sport Predator or Trinity. I run the Predator on my car, SRT-4 Neon, and love it. This is just my opinion that I formed based on modifying my car, please form your own since you have an entirely different vehicle.
I highly recommend joining a forum dedicated to your particular vehicle, do a lot of research before purchasing anything, read, read, read, then read some more. Then start asking questions to other members privately, and the last step would be ask questions publicly if you can't find your answer. A lot of automotive forums have some real jerks and will make you feel like an idiot if you don't follow these basic guidelines. Trust me, I know from experience!
I really hope this helps the least little bit so that you get more excited about your vehicle. Sorry to write a book but I like to share my experiences to help others.
Richard
Hello. I would say the Diablo Sport Predator or Trinity. I run the Predator on my car, SRT-4 Neon, and love it. The Trinity wasn't out when I bought my Predator. Both allow you to upload a 93 Octane Performance Tune which flashes your PCM with a Performance Tune. The Predator is just a plain green screen tuning device and the Trinity is a full color screen with more options such as virtual gauges. Also, you can have a CMR Tuner to do a custom tune for you to maximize gas mileage if you wish, or maximize your performance for current mods or performance mods. Example, say you are looking to get 50hp over stock, you would need to buy fuel injectors that would support the increased fuel requirements, possibly a high flow fuel pump, maybe a cold air intake system, and better flowing exhaust. A CMR Tuner can write a new tune for you tailored to your mods. A dyno tune is always best for tuning to maximize your output. These are just generic statements and more or less hp is possible with stated mods.
Richard
Just curious, why would you need new fuel injectors or a fuel pump for just 50 added hp?
That's why I said "these are just generic statements". Most likely he wouldn't need larger injectors or fuel pump. One way to know, he could choose "Modify Stock Tune" and increase fuel 10% and adjust timing accordingly. After making adjustments he could data log to check fuel injector duty cycle. If it's maxed then he would need to step up to larger injectors. This is based on my car. That's why I also said he needs to join a forum for his vehicle. I am not familiar with tuning his truck!
That 5.4L motor should have 28-32lb injectors stock. Unless that flash is going to get him 300 extra hp, he's fine.
For 50 hp he is not going to need fuel injectors or a fuel pump. Then why would you even mention that if you do not tune vehicles. He would be better off with SCT equipment, much better product.
Stop reading into this too much. Generic statements only. I will edit my post since it is causing an uproar. The DSP is super simple to use. I was just giving my opinion, didn't realize it was a crime.
Diablo is just as good as SCT, but SCT is a more common tuner. Most shops tune via SCT, since its extremely expensive to buy the Diablo Rights.
Not reading into it but that might scare someone in thinking he/she is going to have to spend alot more money when they actually do not need to. It is best to post if it is going to be an actually fact than just a guess, no need to make someone think there is more to something than there really is.
Not true, so I guess we will have to agree to disagree on this. Diablo's product and there tech is nowhere near as knowledgeable as SCT. The reason you may feel it is more common is that it's performance is that much better.
I am not familiar with tuning his vehicle. On my vehicle the DSP is way better because it allows data logging so that you can see what is happening with your engine without buying other gauges. The SCT does not offer this for our cars. For his truck data logging very well may be available. You are correct, to be a CMR tuner for DSP it is expensive.
When I bought my car I thought the same thing, what is the best chip available. I joined the SRT-4 Forum, started doing a lot of research and found out that the DSP was the best option for me. That's why I stress joining a forum dedicated to his particular vehicle!
Thanks guys. This is all really helpful. I have heard alot more about Diablo than SCT. I will need to do a little more research as it stands. Thanks again
This is true in more ways than one. I am just so used to my car and it's like second nature when explaining a tuning device. I did edit my post.
Sorry OP! Before throwing down that hard earned cash, do some research by starting with a forum dedicated to your vehicle. In your situation the SCT may trump the DSP.
The reason you hear more about Diablo because it is the Walmart of tuners not that is a bad thing just everyone knows that name.As far as SCT and HP tuners those are the ones the pro shops use .They make custom tunes for all the top street and drag strip cars.Take a look at one of the top ford tuners Hermann Stoltzenberg for some great reading if your into big H.P.
Not true. Diablo is great for its handheld. Because like someone already mentioned you can data log. Its the best non dyno tune, tuner on the market.
Which is why this is a loaded question. Best dyno tuner hands down is SCT, because its easier to get rights to open tunes for them, and gives more variables to the tuner, to change. Vs. Diablo on a dyno, where its expensive to get rights and doesnt offer near as much tuning options.
Never said it was a bad tuner just more popular .It's the no brainer tuner for the guy who just want to push a couple of buttons and doesn't really care what it's changing or doing
Im definately not a pro and I'm only looking to get more HP and towing when needed and better fuel economy when applicable.
