sparkie
- Aug 9, 2006
- 5,357
I done some more testing on pH this passed weekend.
Duragloss pH is 12.62
Megs pH is 12.80
Purple Power pH is 13.00
Simple Green 9.54
DI water pH is 6.92
This is only 10ml Products before DI water.
This was done 10ml product and 90ml DI water.
Duragloss pH is 11.81
Megs pH is 12.04
Purple Power pH is 12.32
Simple Green 9.89
[FONT=verdana, arial, helvetica, sans-serif]pH: the negative logarithm of the hydrogen ion concentration (-log10[H+]) where H+ is the hydrogen-ion concentration in moles per liter. Neutral water has a pH value of 7. [/FONT]
Anything under 7 is on the acid side. Anything above 7 is on the alkalinity side...
[FONT=verdana, arial, helvetica, sans-serif]acid: any substance capable of giving up a proton; a substance that ionizes in solution to give the positive ion of the solvent; a solution with a pH measurement less than 7. [/FONT]
[FONT=verdana, arial, helvetica, sans-serif]alkalinity: the capacity of water to neutralize acids, a property imparted by the water's content of carbonate, bicarbonate, hydroxide, and on occasion borate, silicate, and phosphate. It is expressed in milligrams per liter of equivalent calcium carbonate (mg/l CaCO3). [/FONT]
Coca-Cola or Pepsi is on the acid side.
Milk is on the alkalinity side.
Megs pH is 12.80
Simple Green 9.54
DI water pH is 6.92
Megs pH is 12.04
Simple Green 9.89
