Pictures & Comments from September 2012 Detailing Boot Camp
Mike made sure to get everyone on a rotary and a DA so we had a chance to really work with them and see what suited us best and how each one worked.
The class was great and Mike and Nick really worked hard to get everybody the most out of the class they could you guys rock:xyxthumbs:
Thanks for the kind words... hands-on training is the most important aspect... and that's why we push everyone to get in there and get their hands on the tools and get to work...
More pics coming up...
:xyxthumbs:
Here's Jeff learning how to use a rotary buffer...
First is the basics and that's how to pick up a bead of product using the 101 @ 10 Technique...
Perfect. Once he gets past the bead of product he quickly lays the pad flat to lock the product between his pad and the paint EXACTLY WHERE YOU WANT IT! Not splattered all over the car or yourself.
Here he's cutting the swirls and scratches from along an edge, also called edging...
Getting a little correction on his angle around the script...
Going up on edge to remove the swirls and scratches around the gas cap...
And how he's making his "Cover Passes" to clean things up and finish out that panel
Nothing like learning to use a rotary buffer on a classic Corvette instead of a mundane rental car...
:buffing:
It looks like everyone had a great time.
It was an awesome class. Great people, cool cars, lots of work, lots of learning, skill that will last a lifetime...
Wait till you see the before and after pictures of the trashed 2008 BLACK Cadillac that was restored using the Meguiar's Microfiber DA System and the 1998 Lincoln Town Car with oxidized single stage paint that looks like it has a brand new paint job after using Blackfire Total Polish & Seal.
:xyxthumbs:
Continued...
Here's Eric working out the swirls and scratches next to the raised body line and curved area on the panel behind the where the convertible top attaches...
Then around the edge of the convertible top...
Then along the back edge...
After edging the panel he knocks out the flat, major portion of this panel and ties all his work together with a few cover passes...
Jay's up next but first he's going to demonstrate how to clean a wool pad on a rotary buffer using a steel spur...
Perfect...
Picking up his bead using the 10 @ 10 Technique...
Cutting out the swirls and scratches around the back of the convertible top...
Then along the curved portion of the raised body line...
Paul's turn and Paul is going to tackle the side of the driver's side rear fender...
Anytime you're using a rotary buffer you need to be looking across from the panel you're working. If you don't have a way to lift the car then you need to lower yourself to the panel...
:xyxthumbs:
Final Results...
After finishing the polishing steps I machine applied one application of Pinnacle Souveran Paste Wax and then took the below video and beauty shots...
Classic Corvette by Chevrolet, Show Car Shine by Autogeek
[video=youtube_share;rs48OLCgP3c&hd=1"]1966 Corvette Show Car Makeover at Autogeek! -...[/video]​
Beauty Shots...
On Autogeek.net
Rotary Buffer Work
M105 Ultra Cut Compound
M205 Ultra Finishing Polish
Meguiar's Double Sided 100% Wool Cutting Pad - Used with DeWALT 849X
Meguiars 7 inch W8207 Soft Buff 2.0 Foam Polishing Pad
Meguiars 7 inch W9207 Soft Buff 2.0 Foam Finishing Pad
Meguiars 6 Inch Solo Easy Buff W66 Rotary Backing Plate
DeWALT DWP849X Variable Speed Rotary Polisher
FLEX PE14-2-150 Rotary Polisher
DA Polisher Work
Meguiar's G110v2
Lake Country Blue Finessing Flat 5.5 inch Foam Pad
Misc
Meguiars Professional Masking Tape Combo
Meguiars Professional Pad Conditioning Brush
Lake Country Wool Pad Spur
Mike Phillips' Detailing Boot Camp - January 26-27, 2013
You can learn to do this kind of work too at my next detailing boot camp class, get signed up fast.
Click here to register for the January class!
How to use the Meguiar's Microfiber DA Correction System
Next up... we'll see how the class does using the Meguiar's Microfiber DA Correction System to remove the swirls and scratches out of a 2008 Cadillac with factory black basecoat/clearcoat paint.
Here's the system our students get to learn how to use in entirety...
Here's our victim... a trashed 2008 Cadillac CTS. Looks good in the shade huh?
Doesn't look as good in full sun...
Here's what the paint looks like in the studio under the florescent lights...
A clean approach
One of the benefits to the D300 and the D301 is you don't have to tape and cover everything off.
That said I have my students for 2 days so I like to share as many tips and techniques as possible and that includes the Beach Towel Tip to cover the wiper arms and the plastic surrounding the wiper arms common to new cars.
They can use this technique to cover these areas and avoid getting splatter on everywhere no matter what product line they're using, they can make this decision, my job is to just show the technique.
The Beach Towel Tip does come in hand for anytime you're using a rotary buffer to reduce clean-up of the windshield, fresh air grills, wipers and plastic around the wipers.
New to machine polishing
Since some of the people attending this class have never worked by machine before including a Meguiar's G110v2 Dual Action Polisher, one of the things I like to do is to show them in a very dramatic way how safe they actually are for your car's paint by turning the polisher on and then,
Holding the pad against my hand...
Actually holding the pad with my hand with the tool turned on...
Pressing it against my hand in the same way it would be pressed against paint - point being it's a completely safe tool even for a beginner.
After centering and placing the pad onto the matching backing plate, the next thing you want to do is prime your pad.
Apply some product directly to the face of the pad and then spread it over the face and work it in well to the microscopic fibers that make microfiber what it is...
You know your students are paying close attention to any topic with pictures like these...
After priming the pad and thoroughly working the D300 Correction Compound over and into the fibers then add 3 small drops of product to the face of the pad and you're ready to start removing swirls and scratches.
Speed Setting 4
Meguiar's recommends 4800 OPM's for removing defects and on the Meguiar's G110v2 you would put the speed setting on the 4 on the variable dial.
Hold the pad flat to the surface, this is done best by using your forward hand to apply pressure directly over the top of the head of the polisher.
Make slow overlapping passes
Then make slow, overlapping passes working a small section of paint at one time. a two foot squared section is usually too large to tackle at one time, especially for a finish with as many swirls and scratches as this Cadillac had, so use good judgment and divide each panel up into smaller sections and then work one section at a time.
When you finish with one section, inspect your results and if the results look good move onto a new section and overlap a little into the previous section.
Inspect Results
After demonstrating how slow to move the polisher over the surface, the size of a section to tackle at one time and what "Section Passes" are and how to do them we turned the polisher off and inspected the results from the compounding step.
RIDS = Random Isolated Deeper Scratches - Not to worry...
In this picture I'm pointing out a random, deeper isolated scratch still remaining while pointing out the millions of swirls and scratches in the paint before we started are now completely removed. No matter what car you buff out you will always tend to have a few deeper scratches that remain and after removing the thousands of scratches that were surrounding them these remaining deeper scratches will tend to stick out like a Sore Thumb.
Second Step - D301 Finishing Wax
Although the results look great there is some light hazing which is really easy to see on black colored cars, but that's okay because the first step is the aggressive compounding step, the next step refines the results from the compounding step to produce a clear, swirl-free finish.
Finishing out...
For the D301 Finishing Wax you don't need to move as slow, use as much speed or as much downward pressure. The Finishing Wax offers light cleaning ability, just enough to remove any haze left by the D300 Correction Compound while leaving a layer of protection behind on the finish. So this step should go a lot quicker and you can tend to tackle a larger section. For speed setting, for the Meguiar's G110v2 set the variable speed dial to the 3 setting.
Inspect your results
For your Test Spot, like we're doing here, it's a good idea to re-inspect your results after working the D301 Finishing Wax. The paint should look clear and reflective with excellent gloss and shine.
If everything looks good then you've proven your system and you're ready to buff out the rest of the car simply by duplicating this same process over each panel. Normally you would start at the top and work your way down. Divide larger panels into smaller sections and overlap a little into the previous section when buffing out a new section.
Here's Audry removing swirls and scratches out of the passenger side fender using the D300 Correction Compound
Here's Erik removing swirls and scratches out of the hood, note how he places his hand inside the D-Handle to position his hand directly onto the head of the polisher.
Here's a short video I took of the Cadillac before the owner picked it up. My next detailing boot camp class is January 26th and 27th and we'll be showing the Meguiar's Microfiber DA Correction System on another trashed, black car.
[video=youtube_share;6ZCXHqj7-Xc&hd"]Meguiar's Microfiber DA Correction System[/video]
On Autogeek.net
The Complete DA Microfiber Correction System
:xyxthumbs:
Wetsanding, Cutting and Buffing Techniques
In my class I share the correct techniques for hand sanding major flat panels as well as how to machine sand using 3M Orbital Air Sanders plus the PC style DA Polishers including the 3" Griot's Garage Mini Polisher as a dampsander.
We use both 3M Trizact discs and Meguiar's Unigrit Finishing Discs in 3" and 6" sizes. After sanding I show how to use a wool pad on a rotary buffer with Meguiar's M105 to remove the sanding marks followed by Meguiar's M205 to remove any holograms left by the wool pad and the M105.
I also show how to use DA Polishers for the final machine polishing step to ensure a swirls free finish on any type of paint with both Meguiar's M205 and Menzerna SF 4500
Here's some shots showing busy, hands on training and practicing...
Here's Audrey showing the guys how to machine sand using the 3M Orbital Air Sander
Audrey has never machine sanded before so after this class she's going to be able to talk about the topic intelligently and she's going to know what she's getting into if one of her customers asks to have their car wetsanded.
Here she is doing it all by her self...
Perfectly making overlapping passes with a quick arm speed...
Now she's using the Porter Cable 7424XP to do the same thing but without having to manage an air line under pressure trying to control the sander.
Time to hand sand, first I show what not to do...
Then I show here what to do...
She has the technique down but says she finds machine sanding easier and faster...
Here we go over the 10 @ 10 Technique
Doug's turn...
Since I already buffed with the pad it needs to be cleaned first, so I show Doug how to use a steel pad cleaning spur.
Perfect...
Now it's time to remove some sanding marks...
Jay's turn...
Time to inspect...
Lester's turn with the rotary buffer...
Continued...
Next up is using a foam polishing pad with a rotary buffer to remove holograms left by the wool pad...
Time to inspect the results...
Looks good!
Here's Chris trying out the Flex PE14 with a Meguiar's W66 Solo Flexible Backing Plate and a 7" Softbuff Foam Polishing Pad with Meguiar's M205 Ultra Finishing Polish.
Here's Eric cleaning a wool pad in a pad washer...
Here's Jay using a Lake Country 6.5" wool cutting pad on a Flex PE14 to remove sanding marks...
After cleaning the pad, Eric is back at work...
Dueling Rotary Buffers!
Lester tries out the Griot's Garage 6" DA Polisher to remove swirls...
Here's Keith using the 3" Griot's Mini Polisher as a Surgical Dampsander....
Here's Erik using the 3" Griot's Mini Polisher as a Surgical Dampsander....
Because of the size this tool is very easy to control and that makes it easy to sand close to edges or in tight areas...
Here's Jeff using the Flex 3401 with a white 5" Hybrid Polishing Pad removing holograms...
Clean you pads often
It's so important to always be cleaning your pad to remove both the paint and the used-up product off the face of your pad or buffing will become more difficult, less effective and wipe-off of residue will become gummier...
Erik testing out the Flex PE14 with a polishing pad to remove holograms...
After these classes are over my panels usually look like black mirrors...
:xyxthumbs:
Hello everyone, new to the Autogeek forum, I did have the opportunity to attend the last Detailing Boot Camp with Mike Phillips and Nick Rutter. It was very informational, and not only did I learn a lot, I met some really interesting people from other states and even Canada, it was fast paced, covered several topics, all in all I was very pleased with what I learned, the chance to try new products, and work on some cool cars. Hats off to Mike and Nick for taking the time to teach expert car care detailing!:dblthumb2:
Here's the students from September 29th and 30th, 2012 Detailing Boot Camp Class!
From left to right, back row to front row...
Will, Craig, Jose, Frank, Chris, Jay, Damon, Adam, Audrey, Juan, Keith, Nick
Erik, Gary, Jeff, Doug, Paul, Greg, Eric
Doug!
Audrey and Juan!
Paul!
Jeff!
Will!
Erik!
Jose!
Greg!
Damon!
Chris!
Hello everyone, new to the Autogeek forum, I did have the opportunity to attend the last Detailing Boot Camp with Mike Phillips and Nick Rutter. It was very informational, and not only did I learn a lot, I met some really interesting people from other states and even Canada.
It was fast paced, covered several topics, all in all I was very pleased with what I learned, the chance to try new products, and work on some cool cars.
Hi Craig,
It was a genuine pleasure having you attend our class. Thank you for joining our forum and posting your feedback. I think you'll find the forum an incredible resource for any of your future detailing projects.
:dblthumb2:
At the end of each class all students are awarded a "Certificate of Completion" to certify the attended, participated and completed the 2-day course.
Robert aka Robert8194
Lester aka FastTrac
Juan and Audrey aka Juans Detailing
Frank aka Freyes5029
Jose - not a member of the forum yet...
Eric aka esv5454
Craig Parker aka Craig Parker!
Paul aka Sailfish
Keith - hasn't joined forum yet...
Adam - hasn't joined forum yet...
Doug aka DextRuss2010
Jay aka In2detail
Greg aka Greg1
Erik
Gary aka highenddt
Jeff aka Motosportlich
Chris aka Bodedetailing
Damon aka Champ2day
I always have copies of my how-to book at my classes and am more than happy to sign a copy while you're here...
Here you go Doug...
:dblthumb2:
Having been to the class three times, it should be obvious that I am a believer in the benefit of this instruction. When I attended the first class over a year ago, I didn't know what to expect. I found that Mike is an incredible teacher and hands on training is worth every penny. Getting to work on cool cars was just an added bonus but the chance to try out new tools and products was invaluable in my case. Everyone who attends the class is either trying to learn about detailing or an experienced detailer who is trying to hone their craft. In my experience, everyone is made to feel welcome, regardless of their experience level.
I especially want to thank Max for making AutoGeek available for these classes and giving us the opportunity to learn about detailing, the correct methods, the best tools and best products.
For anyone considering the class, I cannot recommend it enough. It is an incredible experience. Reading the forum and watching the videos is great but I cannot stress enough the value in having Mike show you hands on how to machine polish. You may be able to learn how to wash a car or detail an interior by video but it is amazing how easy handling a rotary buffer is with Mike at your side (even if I did sling a little polish trying to pick up a bead upside down). Next January, you need to be there. I hope I can be back for number 4.
Thank you Robert for such a generous feedback. I must say it's been great getting to know you and even better it's great to call you a freind.
I showed this to Stacy last night and she says,
"Tell Robert I said hi"
:xyxthumbs:
:xyxthumbs:
Meeting Stacy was a pleasure. I enjoyed getting to visit with y'all. I'm looking forward to coming down in January if my trial schedule will allow.
I was fortunate enough to attend last month's detailing boot camp and I can honestly say it was one of the greatest experiences I have ever had. For me detailing is more than just a job, it is a passion that I can't get enough of. The opportunity to receive hands on training from Mike was a dream come true. I spend a lot of time on the forums especially paying attention to all of Mike's videos and articles and having everything reinforced in a live setting was priceless.
From being able to work on amazing cars with some of the best tools and products on the market to the Saturday night meet and greet with Mike there was never a dull moment. We had the opportunity to meet Nick and a few other members of the AutoGeek staff and what a bunch of down to earth world class guys. They are all so knowledgeable and there's nothing you can throw at them they can not thoroughly answer.
Learning some of the more advanced techniques such as compounding with a rotary buffer and damp sanding by hand and machine were the highlights of this class for me. Every step of the way Mike was constantly giving advice on the minor aspects to speed up the detailing process and create the show car look everyone desires.
No matter what your skill level this class is something I would highly recommend to any professional or enthusiast detailers and would be priceless for anyone new to detailing. Thank you Mike and everyone at AutoGeek for making this special opportunity available and such a memorable experience.
Robert if you attend the class in January I'm sitting this one out and letting you teach it...
Wow!
Thank you for the kind words and endorsement.
I try to not only make my classes educational but also a lot of fun by having really cool cars here for everyone to work on and showcasing all the newest and coolest products being introduced to the market.
My next classes we will be showcasing all kinds of cool new products!
:dblthumb2:
