Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 12
- Thread starter
- #21
Continued....
After machine sanding the headlights the next step is to remove the sanding marks as this will restore clarity to the plastic and create a smooth surface to apply the headlight sealant.
Flex PE14 Rotary Buffer with Cyclo 4" Yellow Wool Pads
The Cyclo 4" yellow wool pads are the perfect size for machine polishing headlights together with the PlastX that comes in the Meguiar's headlight restoration kit. Fact is any quality compound or polish will remove sanding marks out of plastic headlights when using a wool pad on a rotary buffer.
The Flex PE14 only weights 5 pounds and because it's compact in size, it's very easy to use for headlight restoration.
Rotary Buffer Demonstration
Even though you can just dab some product onto the pad or the headlight, smoosh it around and start buffing I showed how to use the 10 @ 10 Technique which the class will learn again when they use rotary buffers to remove sanding marks out of paint.
Hands-On Training
Now everyone rotates through and tests out the Flex PE14 Rotary Polisher to remove sanding marks.
Recap and recover
After each detailing procedure we regather to go over what we just learned and there's time for comments and questions. As the day goes on it's also a chance to rest and refresh with some water, soda pop or coffee.
Notice we didn't apply the headlight sealant yet?
That's because we still have to wash this Tahoe...
Hands-On Training
Recap and recover
