Pinnacle Black Label Cure times?
Centexhokie
I just received my Pinnacle Black Label package with the polish, the paint coating, the tire coating, and the glass coating. I also added in the sealant which I understand can be applied over the paint coating after 24 hours. My questions are the following:
  1. Is there a wait time between the polish and the coatings being applied? If so, how long?
  2. Is there a cure time for the coatings before being exposed to the elements? If so, how long?
  3. Is there a cure time for the sealant to be exposed to the elements? If so, how long?
Thanks.
I'm interested as well.
I dig your avatar btw :)
DVS
Thanks.
Hello!
1. No. Apply coating(s) immediately after polishing.
2. It's best to keep the vehicle dry for the first 24 hours.
3. 3 hours for the sealant.
Enjoy!
Although the Pinnacle formulation is different than the DP formulation (or other similar products), and the work time is a little better, I would say you are looking at the same general recommendations.
Is there a wait time between the polish and the coatings being applied? Nope. You provide the cleanest substrate and you are good to coat.
Is there a cure time for the coatings before being exposed to the elements? If so, how long? If like other coating, you want to prevent exposure to moisture for a minimum of 12 hrs (like CarPro) up to 48hrs (in the case of EXO). We shall get the answer shortly from AG
Is there a cure time for the sealant to be exposed to the elements? If so, how long?Sealant do not normally suffer the same as coating. They have a short cure time for re-application but I haven't seen many that require a non-exposure to the element (except for Wolfgang Deep Gloss Paint Sealant 3.0).
Hello!
Enjoy!
LOL, Nick beat me to the punch! I guess I need to type faster next time :)
