Pinnacle Liquid Souveran Wax Questions
HardLineDetail
I got the 2oz Liquid Souveran sample from my last order and i'm trying to see what's the curing time and when to take it off when applied. Also, should i be applying it really thin? If so, this 2 oz bottle can do like 3-4 cars lol. With 3 small dots i did 1 door. I am applying it over powerlock sealant that has cured for about 24 hours.
Doesn't look like anyone is going to write back. The beading is crazy on this wax.
I can't say for liquid souvern, but for WDGPS I think I can get 6 applications out of the sample size bottle.
Sent from my Galaxy Note 2
Nice beading.
As for your question, I have not used liquid Souvern but yes thinks always best and a little bit goes a long way. This is from the product page:
Directions:
1. Shake well.
2. Liquid Souverän should be applied to paint that's free of contaminants and previously applied waxes and sealants. Use Pinnacle Ultra Poly Clay to remove above surface contaminants and Pinnacle Paintwork Cleansing Lotion to polish the surface. This will enable Liquid Souveran to form a complete bond to the surface, enabling maximum durability and shine.
3. Very important - apply a THIN coat! Apply a Nickel size amount of wax on the applicator and wipe a thin coat of wax on the surface using a circular or back-and-forth motion. This wax is not fussy. Use a motion that you are comfortable with. The beauty of this liquid wax is that you can do sections or the whole vehicle at once.
4. Work on a cool surface, out of direct sunlight. Allow the wax to dry to a light haze and buff off using a clean, soft microfiber towel.
5.Don't hesitate to apply this wax with a machine. Use a red or blue finishing pad with your Porter Cable 7424xp. Set the speed setting between 3 and 4. Work in a back and forth, then up and down motion. There's no need to apply pressure. Buff using a microfiber towel or a microfiber bonnet over a Lambswool 6 Inch Leveling Pad.
*Multiple coats deepen the glossy, wet, 3-Dimensional look. If you choose to apply a 2nd or 3rd coat, wait 24 hours in between applications. Also, wait a day to wash after waxing.
Liquid souveran is super easy to apply and strip. If you apply a thin layer it should be ready to buff off in about 15 min. As with any other liquid wax just do the swipe test.
