Pinnacle Microfiber detergent making my towels rough?
Speed-Dude
I've been using the Pinnacle microfiber detergent I received with a pack of a bunch of microfibers from a VIP deal a few months ago. These included the Deluxe Jr. 600, the Supreme 530, and the Gold plush Jr. towels. However, I noticed that after the wash my towels seemed to feel a bit rough. I've washed a decent amount of loads as i'm about half way through with the bottle now and every time, even though they're clean, they have a rough feeling to them.
My typical wash method is 1.5 ounces of detergent, hot/cold water and extra rinse. Dry on low heat until towels are 80% dry and then hang dry them overnight. No fabric sheets. I've even tried pre-rinsing the washing machine with vinegar before washing the microfibers yet still get this feeling.
Am I still doing something wrong or do other people notice this? I also have two bottles of blackfire microfiber detergent would I notice a difference using that? Thanks for any help!
You are not alone, my 600s and 360 I bought earlier this year all feel rough. I felt that the blackfire does help them stay softer longer.
I use the CG microfiber wash...I've washed some of them several times without any problem?? 530's and Gold plush...
:iagree:
I've also used the CG microfiber wash and the towels actually came out softer than they were new. It also seems to really preserve the "static-icity" of the MF.
However, Blackfire was on my list to try next. No issues w/ CG, just wanted to see if I might be missing out on something better.
Since you already have Blackfire, give it a try. If that doesn't do it for you, order the CG.
Three other points I just thought of:
1) Supposedly, commercial laundry detergents, especially liquids, leave enough residue behind in the washer to actually clean another full load or two without adding any detergent to the machine. (never tested this, just heard it) I have an HE washer and run a machine cleaner through it every other month or so just to cut any excess residue from detergent and/or general muck from laundry. Otherwise, I get a build up on the inside of the drum.
Depending on your machine and normal soap, this could be something to consider. It may be that the vinegar wipe down is not enough on its own to clear everything out.
2) Hard water is not just a P.I.T.A. when washing your vehicle. The same culprit of water spots could be hindering your washing machine as well. If that's the case, either soften the water or add more detergent.
3) As far as drying goes, I do the opposite of your method. I let the towels hang dry to about 80% and then just throw them in the dryer (no sheets) on extra low for about 10 minutes. My main purpose for using the dryer at all is just to build up some extra static in the fibers.
I think most people use too much detergent, just human nature. The problem with washing MF's, is if you have tough-to-cut residues you have to use a lot of detergent, and then it's hard to get rinsed out. With my old top-loader, I have run many, many extra rinse cycles and still get suds out.
I suspect hard water is the culprit. If you think about it, just like hard water will leave difficult to remove residues on your paint if it dries, what do you think happens to your wet clothes/MF's when you dry them? You leave (crusty?) mineral residue in them.
use white vinegar in the rinse ...
Good call. Vinegar will help to break down / remove any remaining mineral or detergent deposits left on the towels after the wash. If I'm thinking correctly, about 1/4 to 1/3 cup in the rinse cycle should take care of the whole load.
Nope. I actually use it instead of fabric softener even for my clothes. They won't smell like vinegar unless you use too much. Even if you do accidentally overdo it, the odor dissipates into the air in the dryer or during the hang dry.
I got the same problem and I don't even dry them I just hang them up to air dry. I have tried 1 ounce of pinnacle and 2 ounces and still feel hard and rough. Even though they are clean I wonder if it is safe to use on paint.
Sounds like you're doing everything right. Try BF to compare.
Hmm looks like most of you suggest the blackfire so I will try that in my next load! It may be a while down the road from now but i'll see and try to update this if I remember.
1) That does seem to make sense. These HE washers use significantly less water than the top-load washers I used to use so i'd assume they don't rinse loads as well. What do you mean by running a machine cleaner?
2) Yeah I have pretty hard water here. Eastern Washington and that area seems to always have hard water i'm not so sure about the rest of washington. I guess I did try to put more detergent but what would you consider to be a small load vs. a full load? I just kinda do whatever my gut tells me to heh but tend to err towards treating it as a large load.
3) Hmm maybe I can try that. I never really had a problem with static though I just worried that the dryer may be heating it past the point it's already dry and that heat could be what is causing the roughness?
See number 2 above. But I do agree, when I lived in illinois my mf towels didn't tend to come out like this even just using tide free.
My HE washer likes to lock the door throughout the whole cycle even if it has drained all the water and I stopped the cycle. How do I add vinegar to the rinse cycle just pour it into the detergent container when it starts?
Thanks for the quick feedback though! This is what I really like about AG and makes me feel more inclined to help others. :xyxthumbs:
Just tried something different with towels after washing them in the pinnacle micro rejuvenator, I hung them up to air dry, they still felt rough and stiff, so after completely air drying them I sprayed each side of the towels with some water just a mist, then I threw them in the dryer on the fluff or no air setting and they came out feeling much better. Still might try the CG wash to see how that works.
1) that does seem to make sense. These he washers use significantly less water than the top-load washers i used to use so i'd assume they don't rinse loads as well. What do you mean by running a machine cleaner?
The one I use is called "Washer Magic". You can order it through Amazon and various other online stores, but I actually found it cheaper at Lowe's. Basically, it is just a solution that you pour into your detergent dispenser and then run through an empty load with the hottest water settings possible.
2) yeah i have pretty hard water here. Eastern washington and that area seems to always have hard water i'm not so sure about the rest of washington. I guess i did try to put more detergent but what would you consider to be a small load vs. A full load? I just kinda do whatever my gut tells me to heh but tend to err towards treating it as a large load.
This one is pretty subjective, as you already know. If I have a load that is roughly the size of a basketball when I pick it up to put in the washer, that is small to me. On the other hand, a load the size of, say, a beach ball is a large load.
As Setec Astronomy mentioned, adding more detergent will help overcome hard water, but it could leave more residue in the towels as well and compound your roughness problem. (A second rinse cycle never hurts in that case.) With an HE washer, you will have to be particularly careful. If you have already roughly doubled the amount called for without good results, I would stop adding detergent and rely more on the vinegar rinse or a method of softening the water.
Washing powder (a.k.a. soda ash, sodium carbonate) is a very effective water softener. Baking soda (a.k.a. sodium bicarbonate) is also somewhat effective, but to a noticeably lesser degree. You could try mixing either of these into your wash cycle, along with the MF detergent, and they should allow the detergent to work more effectively. Oxi-Clean is just sodium carbonate and dehydrated hydrogen peroxide, so you could even consider that an option as well.
Also, any of those three will have instructions on the box about how much to add depending upon the size of your load. You can even throw them directly into the drum with the towels to avoid having to mix them with the MF detergent in the dispenser.
As far as I know, none of these will harm your MF if used in recommended amounts. I have used them on mine in the past as well.
3) hmm maybe i can try that. I never really had a problem with static though i just worried that the dryer may be heating it past the point it's already dry and that heat could be what is causing the roughness?
You're right. It is possible to get the towels too hot and melt the tiny fibers, causing a rough feel. However, it is not likely to happen if using a short amount of time and on the lowest heat setting possible. IME, the static helps keep the fibers separated and fluffy. Plus, I also do this with the MF I use around the house and it significantly increases dust pickup.
Either way, the dryer is not essential and is not likely to be causing your issues with roughness.
my he washer likes to lock the door throughout the whole cycle even if it has drained all the water and i stopped the cycle. How do i add vinegar to the rinse cycle just pour it into the detergent container when it starts?
There should be a separate softener dispenser in the same drawer as your detergent dispenser. Mine is to the right of the detergent compartment and just in front of the bleach compartment. This makes it really easy as it will only dispense from that compartment during the rinse cycle. You don't have to "stand by" and try to catch it in time. Plus, the softener compartment is sort of pre-measured in that you can only pour a certain amount in. This will keep you from using too much.
thanks for the quick feedback though! This is what i really like about ag and makes me feel more inclined to help others. :xyxthumbs:
+1 -- I feel the exact same way about AG :dblthumb2:
i use dp microfiber rejovinator and it makes the towels the same softness like new
BINGO!!
Vinegar is a natural bi-product of a food organism. Throughout the centuries the natural sugar found in fruits, such as apples, grapes, berries, melons and coconuts have been turned into vinegar. Natural starches found in vegetables and grains, such as potatoes, corn, barley, wheat, rye and rice have also been used. The sugar or starch is turned into alcohol first and then completely ferments into vinegar. Today, pure White Vinegar, the most common and widely used vinegar, is primarily made from the alcohol derived from corn. There is no alcohol in the finished vinegar.​
5% acetic acid, household vinegar is in the pantry of virtually every home in Canada - 97%, according to a 2002 Usage Study, and probably has more uses than anything else in your house. Vinegar is used as a food condiment, an ingredient in baking and cooking and in salad dressings, mayonnaise, mustard's, ketchup, salsa, for pickling and preserving, BBQ and hot sauces, marinades and as an all-purpose household cleaner.​
Vinegar's acetic properties make it 'The Perfect Household Cleaner'™.
Pure White Vinegar has been prized for generations for its usefulness as a stain remover, mildew eliminator, soap scum dissolver, chrome polisher, lime descaler, fabric softener, room deodorizer and as an unclogging agent.​
Vinegar is one of those cleaners that's so inexpensive to make and is widely available yet over the past 30 to 40 years it's been silently ignored in lieu of more modern cleaning products like Tide and 409....
You won't believe how soft your towels will be after just one wash...
Thanks for all of the info everyone! Next time I need to wash a load I'll try these tips out and i'm hoping it will work for the better.
I would run the normal cycle with one rinse. Then add vinegar directly to load and select "rinse" where it does one full rinse cycle. Since I got Blackfire mf wash I do not feel the need to use vinegar now but may experiment again.
I hang my to dry, I use Gariot garage gold micro towels. They always turn out soft and fluffy.
