I have tried to scour the forum for some more of the specifics to the DP and PBL coatings and made some notes of my own. I'm sharing them below. It would be nice if these could be elaborated on and perhaps made a sticky, as it is getting difficult to sort through all the discussions for these specifics.
I would also like to know whether the DP and PBL coatings can be topped by PBL sealant (say after 24 hours of applying the PBL coating)?
You can top the coating 24 hours after application if your goal is to achieve a different "look." The only product that I really like topping the coating with is Black Label Synergy. That combination offers the best of both worlds - the glassy, slick finish of a coating with the depth and gloss of a wax.
(I too am noticing a diminished "slickness" in the coating after about 6 months of application on my BSM '15 BMW X3)
The slickness of the paint certainly isn't going to be better 6 months after application. As car care enthusiasts we have an obsession with feeling our paint, which is one of the reasons we introduced Black Label Diamond Coating Detailer and Diamond Coating Booster. Both of these offer a quick way to rejuvenate the incredible slickness that the coating exhibited shortly after being applied. Washing the vehicle as recommended, with Black Label Diamond Coating Shampoo, will also help retain the slickness for longer periods of time.
Rest assured that just because the paint isn't slick, doesn't mean the protection isn't there.
Also, would like to know if you can use Carpro Eraser in lieu of coating prep polish?
Eraser is a great product, but it's not recommended before application of a PBL coating.
Hopefully Nick from AGO can chime in on this discussion too and the 2 questions above.
DP and Pinnacle Black Label Coating Process & Notes
- Wash vehicle with warm/hot Dawn dishwashing soap
- Use either clay bar or nanoskin to remove above surface contaminants
- Polish as desired to remove below surface contamination, swirl marks and or light scratches
- Temperature must be between 60 - 90 degrees during application of coating and for 12 hours after applying coating. Vehicle must be kept dry and inside out of evening/morning dew.
- Apply either DP Paint Coating prep or Pinnacle Black Label Coating prep with DA to prep surface for coating (Both DP and Pinnacle coating preps are compatible with all coatings).
- Apply either DP Paint Coating or Pinnacle Black Label Coating with Foam Finger Pocket Applicator (or Lake Country Coating Applicator). Wipe off any high spots within a few minutes of applying coating. Avoid unnecessary rubbing or touching coating during this process.
- Apply a 2nd layer of coating if desired to ensure even coverage on 1st pass after 1 hour of applying 1st layer (Coating doesn't necessarily layer on top of itself - 2nd pass not beneficial if 1st pass coverage is thorough)
- Allow coating to cure for at least 12 hours in above 60 degree temperatures, without exposure to moisture (including dew - best kept inside closed garage if overnight).
You pretty much hit the nail on the head, with one exception: DAWN!
I'm NOT a fan of Dawn for any application outside of what it was formulated for, and that's to cut grease and grime in the kitchen. It often leaves a film on automotive paint, and in my opinion that's working
backwards. If you need to supercharge the cleaning ability of your shampoo, simply add a couple ounces of a high quality automotive grade APC.
It's been about a year now since the PBL coatings made their debut, and with as many people that have jumped on the coating bandwagon, application errors are bound to happen.
Outside of not following the manufacturer's recommendations at all, here are the most common errors in applying the products:
1. Not enough product is actually applied to the surface. A lot of people get apprehensive about applying a coating (especially if it's their first time), so they tend to apply less than they should, because they fear that high spots will require hours of machine polishing to remove.
These coatings were formulated to be extremely user friendly (ie: bubba proof). It's better to apply a tad too much than a tad too little. Any excess is easily removed with a microfiber towel a minute or two after coating a panel.
For the product to stick, and form the shell of protection that it's designed to, you have to actually apply enough product to the surface.
2. The Surface Cleansing Polish isn't completely removed (especially on glass), and the residue prevents the coating from fully adhering to the surface (more common in colder climates). As with everyone that uses a product for the first time, you have to fine-tune you application to achieve the best results. With the help of a few cold days last year, and by talking to a lot of customers, I've started recommending wiping the paint down with a damp microfiber towel AFTER buffing off the Surface Cleansing Polish. This ensures all residue is removed. So if you accidentally apply the polish too thick or fail to completely buff it off, wiping the paint down with a damp microfiber towel removes any excess product, thus ensuring the paint is bare and ready for the coating. This is a quick tip that only takes an extra minute or two.
:dblthumb2:
