DetailFreak22
- Jan 28, 2015
- 2
I noticed this sort of "pitting" in the clearcoat after polishing. I have a 2009 BMW M3 with the factory carbon fiber roof. I'm using a RUPES bigfoot with a chemical guys blue foam pad, and their V36 polish. The "pitting" cannot be felt with my fingers. It can't be removed with a 50/50 mix of alcohol/water either. I asked Chemical Guys and they said it was clear coat failure after I sent photos.
I'm not a professional detailer by any means. But I don't see how the clear coat could have failed with a DA and a medium-light polishing compound. I didn't do too many passes. I didn't even spend that much time on the roof. I did 2'x2' areas, spread with setting 1 and then worked up to setting 6. I also noticed this same "pitting" on the gloss black window trim, and on the trunk of the car (not carbon fiber, just factory space gray paint). It's not as bad as on the roof. I haven't noticed this on any other panels on the car. I know it's from polishing because it only showed up on one half of the roof (I didn't polish the other half after seeing the results).
It sort of has this cloudy look. In most conditions it looks perfectly fine. But under direct light from the sun or from overhead lighting you can see it. Have you seen anything like this before?
Photos attached. Look where the light source is in each photo to see the "pitting".
The third photo shows much less pitting than the others. This is the front of the roof, closest to the hood of the car. This is where I started. The pitting gets worse the closer you get to the back of the car. Maybe the polish was breaking down? I noticed the polish started to spread dust. They claim the V36 polish compound is not supposed to spread residue. The first few panels I did with the pad there was no dust residue.
I'd like to know what caused this to happen and how I can prevent it in the future. Was it my technique? Was it the product breaking down? Was it the pad getting old?
