Hello,
Im putting the car pro sic coating on my sisters Lexus this weekend. Does it matter what polish I use as a last step if I use eraser?
Thank you
Yes and no. It doesn’t matter which polish but it would matter if it were a one-step polish with protection. Some one steps include 2-4 mo of protection which Eraser wouldn’t completely remove and would interfere with the coating. BF Onestep, HD Speed, Rupes Uno Protect are examples of one steps with protection.
I will also throw out Gyeon Primer and CarPro Essence as SiO2-infused polishes that are supposed to help a coating bond but not sure how true that is. But even with those, you need to use Eraser or similar to remove the polishing oils before coating.
Good luck.
I thought you could coat right over Gyeon Primer? I thought that was one of the selling points of it?
PRE COATING PAINT PRIMER
I am just learning a bit about a primer before a coating and have also heard something about a product called essence?
+1I used Angel Polish Primer before applying their Cosmic V2 Glass and it was a little different process, you apply the primer and buff it off before applying the glass coat, but no prep
Meguiar’s D302
As Noorth mentioned, Gyeon instructions say you should wait 24 hours for the primer to cure or more likely for the polishing oils to flash off before coating and if less than 24 hours, you should use a prep spray. But like Noorh also mentioned, if you wait 24 hours, there would be dust or similar on the vehicle.
Dr. Beasley’s is one I know can go from polish straight to coating without a prep spray.
Waterman, like others said...use any polish you want just no AIO or cleaner wax products
I thought a cleaner wax like P21s was fine before coating?
Hello,
It’s funny. I just bought ultimate polish Sunday and already have perfecting cream. I bought ultimate polish on sale because I think this will work very well on my sisters car.
You should get another bottle and give it a try, I will be shocked if you dont like the end results ( not talking about the application process )Good luck with the SIC. I have a bottle but haven't used it yet. The flash time had me throw it on ebay, but it looks like the car I have on Friday with be my first go round with it.
