In theory, to get some additional bite, could you use a lighter polish on an MF cutting pad? I'm working with hard paint, nothing major in terms of defects but want a bit more bite. Thanks!
I've read numerous accounts of M205 and other polishes being used (sometimes to great effect) on foam cutting pads but can't say I've heard of anyone doing that with a microfiber cutting pad. Microfiber already has more bite than foam and while I don't use them myself, I imagine you'd have more problems with marring on softer paints.
http://www.autogeekonline.net/forum...on-opti-coat-anthony-s-auto-detailing-nj.html
M205 and MF cutting pad. Worked well based on results showed.
Kind Regards.
I'm sorry, I'm Brazilian, and sometimes I may misunderstood what was written.
OP (of this thread, asked):
'could you use a lighter polish on an MF cutting pad?'
My answer:
'read some input on M205 and Meg's MF cutting disc working wonders'
Anthony answered to me on that thread (page 2):
'I am sourcing the link to Kevin Brown's method with M205 and MF disc, I will post it by tonight. It has replaced about 90% of my cutting work now...it really is amazing. You use a TON of discs and M205...but the time and effort saved easily make that worth it.'
I've saw more info regarding that, but couldn't find it easily. On the web you can find the Kevin Brown reasoning on this subject like I said.
Maybe my answer now to OP would be, you can, but it's likely you'll need a second step to finish down?
It's very common when cutting with microfiber. Meguiar's themselves made the whole DA system a 2-step approach in essence.
Again, sorry if I understood something wrong.
Kind Regards.
I believe you did a very good job.
Also, thanks for sharing your outcome. It's hard to see the haze you're relating, from here, but the overall improvement is very noticeable.
Had you tried to do some M205 on foam finishing pad after that?
Very well done,
Kind Regards.
Nice to hear, very interesting refinement you chose with SF4500, congratulations on your approach.
If you eventually place a write up on this, please, let me know via MP so I can follow the thread.
Kind Regards.
