Polisher for weekend warrior
I thought the same with my GG3. It wasn't the bearing, but the housing part that holds it. See the pic.
I called Griot's as well, but in my case, I think they wanted my old tool plus some money on top. I declined the offer and instead saved a little more and got the PXE.
Sent from my SM-N960U using Tapatalk
Really? That doesn't sound right.
I'm not saying it didn't happen, but that isn't the Griot's CS that I know. :dunno:
Interesting. I guess thats what was starting to happen to mine.
I offered to send mine back for repair and they asked for a small amount of money in return for a new machine. I obliged and they sent over a new G8.
That is awesome !!!!
On a different note... if I call and sent my GG3 plus some change, I would get a new G8??? LOL
I been using the GG3 for interior scrubbing and lately it is started to sound like a diesel. :D
If you don’t mind me asking what was small amount and did it cover shipping?
Time to send it in if it sounds like that.
Leaning toward going the Griot’s direction based a lot on the warranty. Sounds like they honor the warranty well.
I too would go with either a G9 or if you have the coin FLEX. I have a GG6 still and it gets used about 40/60 with my FLEX. Great machine and great company/warranty. The GG3 I have is still holding up but if or when it goes I would be happy to pay $60 for a new mini from them.
I would seriously look into the g15. Longer throw will save you more time and cover more area. Love mine.
It will go anywhere a g9 will but is just better. Went to add a g9 to my arsenal but just don’t think their is a time i’d woop it out over the g15.
Will spend more and get a PXE, Nano or maybe a beast...
I assume there’s a reason that @MikePhillips recommended the G9 over the G15.
Probably only because if one person wants a single machine, it shouldn’t be a long throw. But if you have plans to also buy a 3” polisher, then it would be a great pair to have the G8 and a G15 instead of a G9. If getting just one machine, I’d go for the G9 with a 5” backing plate.
I have a 3” backing plate on the PC as it sits. And I’m not above buying another machine in future. I’ve been eyeing the little Rupes Nano or copy for the little tight bits on my MINI. If that’s the only reason then I’ll take a look at the long throw machine.
For a beginner, a smaller throw machine is easier to work with and runs cooler. The longer throw machines pull and jerk a bit and the pads can overheat. The longer throw machines do correct better though. The G9 is probably the best beginner choice.
Started a thread in Autogeek101 about the first correction of the year - my wife’s Tuxedo black Navigator. I’ll use the PC unless I order soon. BTW, it is a 7424; i loooked.
Reached out to Griot’s to see what they say about which one they’d recommend but haven’t heard back. How many days does it usually take them to answer an email?
Some things I’ve read about Rupes that sounds good to me: they are often described as smooth and don’t really need a lot of downward pressure. With neuropathy and being strength compromised, that might be a bonus.
Long throw machines are more technique dependent to get around curves without stalling. I like using gear driven DA for the heavy lifting and finish down with a long throw. The pressure I use for the gear driven machine is generally equivalent to a firm handshake. Heavy pressure comes in to play only when dealing with heavy defects.
The G9 is a nice compromise since it has the power and pad stall is at a minimal plus it doesnt require you alter your current buffing style coming from a Porta Cable.
Not sure but you could try calling them
^^^This^^^
GG customer service is top-notch.
Just like any big company, they get thousands of emails. But a call is immediate, and they are very customer friendly on the phone. :)
I’m 98% sure I’m going with the G9. Two hesitations...
1) Do I really need a new polisher? The PC works pretty well but efficiency is a big deal with me; I have so little energy.
B) The whole Rupes smoothness thing.
1) You don't need a G9 to replace a PC. You gain some more power and better ergonomics but I don't think it will make you a lot more efficient. It's still a short throw free spinning tool. If you want more efficiency/speed you need forced rotation like a Flex Supa BEAST or the Rupes Mille.
2) Rupes makes great tools. But they don't have the Griot's warranty and to me that means everything. Since I don't use my polisher all the time, I want to have a machine that will be fixed if it fails in a few years. If I bought a Rupes and it failed after 18 months, for example, and I only got to use it 2 or 3 times, I'd have to pay for service. To me, if you believe you make the best polisher, you stand behind it and provide better warranty. Maybe limit warranty to professionals that beat their tools to a year but for the hobbyist that only does a car or two per year, the warranty should be several years (or like GG, make it lifetime).
