Polishing A pillar with 3" DA.
BigB02Z28
Hello,
I am curious if you have to do a criss-cross pattern? I have the 3" GG DA for A pillars but its just small enough to basically rub back and forth horizontally, is this substantial or do I need to do little 2" vertical-ish passes?
Also, Do you break up the 2" painted areas that surround the window or can you run over the entire section in 1 pass?
An 18x18" area has more surface area than say a 30"x2" area but to me it seems to dry out faster on the opposite ends by time you get there.
Thanks!
(Reason I ask is I am having correcting issues on small sections with the 3" Griots machine. Not sure if its because I'm not criss crossing or I'm not use to the weaker machine?)
I don't worry about changing directions on narrow sections of panels or pillars when compounding or polishing or waxing for that matter. There is a saying "let the panel be your guide." If it doesn't make sense to alternate directions like you normally would then just don't do it on that one area. Obviously you will still want to get even coverage/correction but you can still do that going back and forth in the same direction and overlapping your passes.
I have never used the GG 3" DA but even with my PCXP and 4" pads I still have to make a few passes on the A pillars to make sure I get everything.
Hello,
You don't. For thin panels you just run the polisher back and forth in the direction of the length of the panel.
"Sometimes all you can do is all you can do"
Here's what I wrote in this thread, see post #3
Alternating Horizontal/Vertical Section Passes?
Second, because some panels are not large and flat, especially on modern cars which are aerodynamic and for this reason very curved, then you use what I call the Yoda Technique, that is you,
"Let the panel be your guide"
(When you read the above sentence, use your best Yoda impersonation)
So of course, if you're working a long, thin panel then you might best work that panel by only going in one direction and doing your best to overlap your passes.
Basically whatever it takes to get the job done.
One pass, see above...
Correct. I talk about that here,
Tips for working in warm/hot weather or direct sunlight
Shrink your work area down to a smaller size...
Anytime a product becomes difficult to work with, one tip you can try is to shrink down the size of your work area. This means you spread the product out over a smaller area and only work this smaller area.
Be careful not to allow yourself to do what I call Buffer Creep. This is where you creep outward from your original small section and end up buffing out a larger section. Avoid Buffer Creep. Especially if your product appears to be drying up and becoming dusty.
Why a smaller area?
Because when you're working only a small are you're continually engaging the working film of product over the area more quickly as you move the polisher and by doing this there's less time for the product to dry and dust.
I've removed #2000 grit sanding marks using only a foam pad and a medium cut polish with this tool so it CAN do correction work but what I always tell people is you have to use EXPERT technique and by that I man focus on the task at hand and be sure to mark your backing plate and then hold the pad flat to the surface and vary your downward pressure to maintain pad rotation.
Video: Mark your backing plate to make it easy to see pad rotation
Good questions!
:dblthumb2:
I think for the yoda one, it should be "your guide, let the panel be"....then again, im just a dork.
I appreciate the responses and help guys! Mike I am shocked that you can handle so many things at once. You certainly seem like a busy guy yet you always take the time to respond to everyones questions.
I just watched that 2.5 hour long video that you did on a red Mustang, I believe the owners name was Brandon? You used a rotary to "surgical buff" and I was wondering If I should have bought a rotary to do those smaller panels.
Either way, I love the GG6 and the 3" just seems a bit more touchy to me, I don't have any issues with the machine, I just need some more seat time.
Appreciate the help! Thanks!
