HateSwirls
- Jun 24, 2013
- 3,632
I use PlastX which works well.
I also use m205, all done by hand works for me.
Is there a better tool to use than a powerball ?
..megs has the dynocone...
Thanks
Well first off there is no such thing as "plastic chrome"
It's chrome, period. What ever is under it has nothing to do with Chrome.
When you "Chrome" something, metal, plastic, wood, glass or anything, it still goes in a nickel bath. period.
I'm wondering if anyone has had success with this? My grill surrounding trim was pretty beat, so I figured I would try polishing it, the OCing it. I figured if it ruins it, I'll just replace it and coat the new one before I install it.
Well, it ruined it. It came about with tan dots all over and it lost some of its reflectiveness. I guess this material can't be polished? I used 3" HT pads on a GG6. First I tried Optimum Polish II. That wasn't working, so I went to Compound. That wrecked the finish.
Anyway, I ordered a new one. This one is matte black, so hopefully it will hold up better and is likely polishable.
I'm just wondering if anyone knows why it didn't work?
.replaced by PVD processes.
.....increased investments towards elemental chrome PVD coatings to maintain the true chrome appearance.
.....For this reason, PVD chrome has not been deployed in any significant volume in the exterior automotive market.
PVD (Physical Vapor Deposition): A superior approach to chrome plating
Improved functionality and flexibility are the main advantages of the relatively new coating process "PVD coating for plastic parts". PVD coating is a multi-stage process. The parts are first pretreated with a primer coat. Thereafter in the PVD process itself the parts are "sputter coated" in a vacuum chamber while electrically charged. Finally a protective clearcoat layer is sprayed over the metallic finish. Unlike chrome plating there are no cyanide dip tanks or other chemical baths that have negative environmental impacts.
PVD is not being used
THE ABOVE ARTICLE SAYS IT'S NOT BEING USED.
Yep, zero scratches. Actually, I tried my hardest to scratch it in an area that would be covered anyways and I did get it to scratch. So I scaled back a little and continued onto the whole thing.
Sent from my T-Mobile G2 using Tapatalk 2
