First time poster. I've done plenty of research on the site, but I'm still not sure which polishing products to get for my new BMW 3 with a Sparkling Brown metallic (it has flakes inside), so I wanted to ask if any of you have any experience with this color.
The car is only two months old, and I've only hand washed it (two bucket method / rinseless) since, but the paint did have plenty of swirls from the dealer.
I've heard great things about Menzerna polishing compounds, but I'm not sure which one(s) plus which pad combos would be best suitable for my paint. After cleaning, claying and possibly Iron-X, I want to polish (and/or pre-polish before if necessary) and top it off with wax/sealant – I read that Blackfire works better with metallic flake paints, but open to suggestions.
I already have a small Griot's, and I'm looking to get the Flex XC3401 for the polishing process (will use it on other family cars too).
PS – I understand that it takes anywhere from 4-6 pads for polishing, but I also saw the Edge Foam Pad Conditioning Brush on the site, is it effective in reducing the number of pads you use for each car?
From Mike's post for new cars:
1. Wash and dry.
2. Inspect the paint with your sense of touch and visually in bright, overhead sunlight.
3. Iron X paint and wheels - Then re-wash to remove the Iron X residues off the paint and wheels.
4. Clay - If needed. Your inspection will tell you.
5. Polish - If needed. Your inspection will tell you.
6. Apply either a Car Wax or a Paint Sealant
Welcome to AGO!
So when you say "small Griot's" are you saying the GG3? If you have the GG6 you really don't HAVE TO have another unit to do your new beemer. Just make sure you have the 5" backing plate.
The Flex is another beast ALL---TO---GETHER. Compared to the GG6 being a coupe, it's a 4x4 extended cab truck. It can (and will) give you the ability to finish down fantastic. But the GG6 can also finish down just as well, (it'll just take you a bit longer on the job as a whole).
You said you might possibly Iron-X. Don't skip it at this point, you'll be glad you did it, trust me. DO NOT do it in the sun, or on a hot car however. Clay, IS NEEDED. This is where I cannot stress enough that you get a Nanoskin pad. If you have the GG6 then get the 5½" Nanoskin pad. That puppy will clay the entire car for you in a matter of minutes. Don't have to worry about dropping it (and having to throw it away) and it'll last for at least 6~10 uses. Sure, it's twice what a block of clay is, but it lasts a LOT longer. That and knowing you can rinse it and keep using it makes it a lifesaver.
If you don't have a buffer to run with it, then get one of the hand held ones. The twin-pack with the blue and red ones are amazingly handy to have around. They have a squared edge on one end and a rounded one on the other. This'll allow you to get right up to edges, trim, you name it. Again... this is a tool you really need in your arsenal.
Then you said you've read that you need pads. YES YOU NEED PADS. Get yourself AT LEAST a dozen, I'd say 18 to start. I've been preaching for years now that I wish Autogeek had a "Detailers Dozen" similar to a "Bakers Dozen" where you could order 13 pads for the price of 12. There I'd go for 4 orange, 4 white, 3 blue, 2 black. Honestly, I'd say get 6 white, the 4 (or 5) orange, 3 blue, 2 (or 3) black, 2 red. That'll cover whatever paint systems you'll run across. (
Notice that last group would be 12 all by itself.)
On that BMW you may actually be able to get away with only 2 (types/cut) pads. That and FG400 and you'll be surprised what it'll do. You can start with an orange or white pad and work the FG400 most of the way through it's duty cycle, then switch to a blue or black pad (maybe even a red one) and finish it down. This isn't exactly a 2-step method, this is what I call a 1.5 step method. Saves a TON of time and gets great results.
If you want to REALLY make it pop.... get Menzerna SF4000 after you've compounded it with FG400. That combo is darned near invincible. Of course you can get results that are just as good with Meguiar's (and likely take LESS time doing it). After your test spot tells you how the cut is going you'll know which compound will get it done for you. Personally D300 has become my favorite compound the last couple of years. I'd skip M105 completely. Also, Ultimate Compound with an orange or white pad does great. Finish it down with either M205 or Ultimate Polish and call it a day.
Wax or sealant?
SEALANT!!!!!!!
Meguiar's Ultimate Liquid Wax is actually a sealant and is better than it has a right to be, (for the price that's for sure). You can also top it with M26 Yellow Wax (which is ALSO a sealant despite it calling itself a wax) yet it does have carnauba in it as well. The GREAT thing about M26 is it has a DOI rating off the charts. (DOI= Distinction of Image which is a rating of how glossy, how clear, how reflective it is.... and it's in the 90's and has been for years.)
Wolfgang Deep Gloss Paint Sealant 3.0 will serve you well. Either that or Menzerna Power Lock and you'll be happy.
Another choice would of course be one of the WOWA sealants from BF or WG, both of which are good. I just prefer WOWO to them after I've gone to the effort to properly buff and polish a vehicle. I feel that the protection is head and shoulders above the WOWA products. Where I do use them (WOWA) all the time though is in all the jambs. Trunk, hood, door, you name it. Just WipeOnWalkAway.
Also I'll use them down the road for maintenance (after the initial buffing/polishing session).
Again, :welcome:to AGO! :cruisin:
