thanks, im trying to remove swirls under klasse sealant, basically start over. didnt have any luck doing it manually.If you're talking about using a 6.5" pad in a tight area a a DA style polisher then no they won't work as the "tight area", usually a curved panel or a body line will stop the pad from rotating thus no correction ability. For this you want to use a smaller pad like a 4" spot repair pad.
What are you working on and what are you trying to do?
