polishing tighter areas
molarman
will the 6.5 inch pads work o.k. in tighter areas without spattering? also, has anyone had success using the polishing pal with 4 inch pads removing swirls by hand?
If you're talking about using a 6.5" pad in a tight area a a DA style polisher then no they won't work as the "tight area", usually a curved panel or a body line will stop the pad from rotating thus no correction ability. For this you want to use a smaller pad like a 4" spot repair pad.
What are you working on and what are you trying to do?
thanks, im trying to remove swirls under klasse sealant, basically start over. didnt have any luck doing it manually.
