WRAPT C5Z06
- Nov 12, 2009
- 12,615
I've always used a dedicated clay lubricant. However, I'm thinking about using PB's S&W as my drying aid as well as a clay lube. Is it a great clay lube?
Cost is not an issue. I'll give it a shot. I like to have the least amount of products to get the job done.I've used S&W as a drying aid as well, but never as a clay lube. IMO it's too pricey to be used for this purpose. I've settled on ONR at quick detailer strength for clay lube. It's a cheap alternative and works well. If cost is no concern, give it a shot. I can't think of a reason why it wouldn't work well.
I'm thinking S&W may be too slippery as well.ONR at QD strength (8oz/gal) may be too slippery to be used as a clay lube. The recommended clay lube strength is 2oz/gal.
Thanks!You can absolutely use it! And like some have said if you are going to use it as a clay lube you may cut it 50/50 just for claying not for using it as a waterless wash. I use it full strength and slipping is no issue at all. You use it for a drying aid?? I use S + G I'll have to try that sometime I just like killing two birds with one stone haha do my QD while I dry and reduce water spots etc.
Thanks!
I purposely use S&W as a drying aid instead of S+G because I don't like any "quick detailers" altering the look of my LSP. S&W is perfect for me! :dblthumb2:
I've used fk425, it looks great. It's just a personal preference not to alter the look of my LSP
Yes, it would only be for cost efficiency as I prefer to use it full strength and never heard of the clay eating thing in fact when we store our clay we spritz in some S&W to keep the moisture level up no negative effects. I have had an APC basically dissolve clay lolThanks!
Would diluting it as a clay lube only be for cost efficiency? I thought I read somewhere that S&W ate up their clay. :dunno:
Thanks!Yes, it would only be for cost efficiency as I prefer to use it full strength and never heard of the clay eating thing in fact when we store our clay we spritz in some S&W to keep the moisture level up no negative effects. I have had an APC basically dissolve clay lol
I already have it! :righton: I use it as a dryoing aid, but wanted some opinions as a clay lube.Hey Mark,
Don't read anymore post!!! Get it, it works great! It's all I use and the 128oz will last forever!!! It's good sh**.....
