Edge Pads, straight from the site,
The Edge 2000 6 Inch DA Pads: The Edge 2000 6 Inch DuraFoam Pads will change the way you think about buffing pads.
Yellow Cutting Pad This pad is aggressive, and will cut through deep surface marks and swirls.
Green Medium Cutting Pad This pad is useful for light oxidation and moderate to severe swirls and imperfections.
Orange Light Cutting Pad This pad is highly versatile, as it can be used on cars with light to moderate swirls and imperfections. We recommend you begin with this pad if you are unsure how deep swirls are, moving up to a Green Medium Cut Pad if necessary.
Blue Finishing Pad This pad is great for everyday use. It will leave surface areas scratch-free and smooth while still removing light swirls and imperfections. Use with wax and polish to apply a fine gloss. Safe on clear coats. 70 pores per inch (ppi)
White Ultrafine Polishing Pad This ultra-smooth polishing pad contains 80 pores per inch, allowing for fine polishing which creates a bold, crystalline gloss Use this pad to apply waxes, polishes and sealants. Safe on clear coats. 80 pores per inch (ppi)
Red LSP Finishing Pad Autogeek exclusive!
The red pad is softer than the white pad, which makes it perfect for new car finishes.
