I installed power locks, windows and keyless entry on my old chevy cobalt. I used this Universal Power Door Lock Kit (2 Door)-2 Door Lock Kits
Everything is pretty straight foward, find a mounting spot for the actuator on the door then bend the rod right to connect the actuator to the door lock rod. After that its just running wires. Just don't order a keyless entry system from them. I got a viper, I originally got one from them but it was crap unlocked and locked randomly I pulled it after a couple of days.
Btw this system is a central locking, you lock one door the other one locks, no switch with it. You can pick up one if you want it's about the same as wiring up a keyless. Just one thing you will need to solder the switch or keyless(if you choose to add these now or later) to the power lock control module circuit board. It's really easy I can pull out some old pictures if you need it.
