GPM - the more the merrier. Going to fall into a gasser but they do make decent commercial spec electrics on 220V ranging from $2K and UP. Then you add another $400 or so depending on the outlet distance and some 8AWG cord depending on distance.Found one on the river with 4,800 PSI and 3.2 GPM for $112.00 and free shipping.
Yeah, might use it twice a year.GPM - the more the merrier. Going to fall into a gasser but they do make decent commercial spec electrics on 220V ranging from $2K and UP. Then you add another $400 or so depending on the outlet distance and some 8AWG cord depending on distance.
Half that should net you a decent gasser that will last you a lifetime. Price is relative to the quality of the pump and engine which is mainly the 2 guts if a PW.
$112 for a unit....might now last long time, but might last long enough for your needs....
Looking for a power washer for all around cleaning especially the pool area. Prefer an electric because of the noise.
I take it that GPM is important.
Lot of trees and greenery and falling debris on out door furniture. Yes, bleach on the concrete areas does the job.Ain’t nuthin easier for cleaning the concrete around a pool than a few gallons of plain (no scents or other additives) generic, bleach and a push broom…any concrete for that matter.
Did it around our pool for years each Spring. Bleach goes into the pool…no problem, it’s just weak liquid chlorine! Low effort, great results.
Sent from my iPhone using Tapatalk Pro
