Powerwasher w/ Foam Cannon?
Definetly looks like it will work to clean the car.... Make sure you have a quick disconnect able tip on your pressure washers wand. 2700psi is a lot make sure for rinseing and everything else that you have a 40degree or wider and don't get too close to the paint with that much pressure. Mtm foam cannon is what I have and use. Love it
Figured it out.. Kranzle is the fitting.
Purchased! Can't wait to use this! Im the MAN
Good deal definetly makes washing the car more fun. I recommend honeydew cg soap works well for me.
The ph level of your water plays a huge role in how much foam you can produce and how thick it is. I have hard water so I picked up an in line water softener did the trick for me. Have fun.
I bought a gallon of the DP extreme foam about a year back in conjunction with the foam gun..But the foam gun absolutely sucked.
Which water softener would you recommend?
I have this setup that I picked up at Home Depot (never thought to look on ag... )
http://www.autogeek.net/deluxe-filter-system.html
Using it for 3 months now and haven't had to change the cartridges (there is also a cartridge refresh kit at homedepot for like 10 bucks I might give that a shot when the time comes otherwise I think the filters were like 20-30 bucks for the two)
Initial cost is expensive but I don't worry about water spots like I used to... And to me that in itself was worth it the thicker foam is just an added perk)
The Home Depot sells a Foam Gun for about $20.
Oh I like the Gilmores & all the other pricey guns. Even purchased a couple. But your just applying soap or car shampoo. The cannon from Home Depot does the job!
