Prediction - More one-step Cleaner/Coatings or Primers
Been wanting to post this thread for some time now, today seems like the time. Historically, the category for products that clean, polish and protect is called,
Cleaner/Wax
Now days, everyone uses the word AIO or All-in-One. So that's why in the title I switched out the word wax in cleaner/wax and used the word coating so cleaner/coating. And in the short time that this new aspect of this category has been around the word PRIMER has been used and seems to be sticking.
Here's the term I like though, (nothing wrong with the word primer)
Ceramic AIO
And the word ceramic in the term Ceramic AIO is being used in the general sense of the word. The protection ingredient may be something non-ceramic but it will be in the nano family of things.
With all the popularity lately with one step AIOs or cleaner/waxes, that is, products that will compound, polish and wax the paint in one step. Or compound, polish and seal the paint in one step, I predict, moving into the future there will be an increase in one-step products only instead of a traditional wax substance for protection or a traditional synthetic sealant for protection these new products will use some form of ceramic nano glass particles for protection AND be compatible with topping using a ceramic paint coating.
Here's the current selection of these types of products on the AG store.
GYEON Q2 Primer 1000 ml.
CarPro Essence Xtreme Gloss Enhancer 500 ml.
Hybrid Solutions Ceramic Polish and Wax
Dr. Beasley's Nano Surface Primers
I know of at least one chemist, possibly two chemists working on such products.
:updated:
NEW
Became available after I wrote this article back in 2018. (I'm vindicated again)
Dr. Beasley’s NSP Z1
Dr. Beasley’s NSP Z1 is a one-step primer and nanocoating designed for new or lightly contaminated vehicles. Dr. Beasley’s NSP Z1 works best on cars that don’t need a high degree of paintwork correction as it contains a unique nanostructure. The formula of Dr. Beasley’s NSP Z1 is made with TiO2, SiO2 and engineered abrasives. Protecting your car for a year or more, Dr. Beasley’s NSP Z1 can be layered with waxes, sealants and other coatings.
Dr. Beasley’s NSP Z1 is a nanocoating, making the surface of your vehicle scratch resistant with improved hardness. As nanocoating, it will also make your car easy to clean, protect against staining and etching, while still producing a sharp, hydrophobic gloss. The nanocoating that makes up Dr. Beasley’s NSP Z1 has resin formula that contains SiO2 and TiO2.
But what exactly are theses SiO2 and TiO2 compounds that it contains? You may have heard of SiO2. SiO2 brings you water beading capabilities and shine, as well as durable protection. TiO2 is not as common. TiO2 is found in nanocoating’s and is scientifically called titanium dioxide. This compound is white in color with reflective properties. This means that TiO2 can scatter and absorb UV rays, while also heightening brightness, being non-toxic and non-reactive. Therefore, with the combination of these two compounds, you get enhanced durability, protection, water beading and shine.
Dr. Beasley’s NSP Z1 is also made with microsphere abrasives that blend together several grades of cutting, buffing and finishing particles in one to achieve a multi-step shine in just one step, hence why it is referenced as a one-step primer. The larger microspheres cut, the smaller microspheres buff and the diminishing ones finish. All these microsphere abrasives lead to deep reflectivity.
You don’t have to think twice about applying Dr. Beasley’s NSP Z1 on top of other products as it can be layered with waxes, sealants and other coatings of similar durability. Plus, Dr. Beasley’s NSP Z1 will last you at least one year’s worth of protection.
Directions:
-For best results, conduct a thorough decontamination prior to application.
-Starting with a panel or small area, conduct 5-8 section passes using a foam pad and machine buffer at a medium speed.
-Wipe away with a clean microfiber towel and visually inspect paint with a powerful light to observe results.
-Repeat steps 2-3 on each panel or small area until all paintwork has been buffed to desired results.
After Care:
-To ensure durability, wash every 2 weeks with Ceramic Body Wash and rejuvenate every 3 months with AdvanceCoat: Gloss. With proper after-care, NSP Z1 protection can last a year or more on even a daily driver.
8 oz.
Re: Prediction - More one-step cleaner/COATINGS or CCAIOS i.e. Ceramic Coating All-in-One type products
I'm pretty sure Nick has said they are working on a primer polish as well. Can't wait to see what they come up with.
That's ultimately what I'm hoping to see soon. The time savings and hassle of having to put a coating on after a good polish would be nice.
Very cool. Thanks
I’m very excited by your tease, Mike! I did purchase the BF Pro Primer (as I mentioned to you in another thread) and am looking forward to using it... but having fine abrasives is a critical benefit for me to save using a separate finishing polish step first.
The other thing I hope the chemists *might* be thinking about is an Ech2o rival.
What I struggle with and I know a lot of other people struggle with is how to chemically strip softer dark colored paints without micro-marring the paint at the same time.
If a person could create a true finishing polish that worked on soft paint or any paint and left behind a base layer of some form of ceramic coating that could then be topped without stripping, now that would be the way to go.
I'm still going to predict more smaller wool pads and foam jeweling pads for rotary buffers into the future too...
Are you referring to a step to use Eraser inbetween polishing with Essence and applying the coating on top?
On a similar note, does the “stripping” step need to be done after Pro Primer Polish, before a coating or SiO2 Spray Sealant application? Directions don’t mention a wipe down in between.
I love the idea of an AIO or CCAIO (ugh, another acronym) for vehicles with soft paint, the drawback I see is the logevity. I've used a couple of AIO's I really liked, but the protection they provided lasted only a few weeks.
If someone could develop an AIO able to stand with the more durable 6-months sealants, or eaven the weeker 1-year coatings, I'd be VERY intrigued. I've got two Japanese cars in my driveway which could benefit from that type of product.
Now, if they made one with the bite to take on German paint...
Britemax Virtue SiO2 High Gloss Primer Polish
Maybe get one to do review of this.
Copy from the product page:
Britemax Virtue SiO2 High Gloss Primer Polish doesn’t have to be used as just a prep product. Strong enough to stand on it’s own, Britemax Virtue SiO2 High Gloss Primer Polish will leave your vehicle’s surfaces protected and extremely hydrophobic for up to 6 months!
I know 2 other brands that has a primer polish with Sio2 that also has high hydrophobic ability. One I know of is made for to be a CCAIO. And then use either their Sio2 car soap or Sio2 QD or use them both. Have this 2 maintance products and are very satisfied with them. The QD has a long longevity for being a QD. And the Sio2 car soap leaves enough protection between 2-4 weeks. The Sio2 QD leaves at least 6-8 weeks of protection. Or should say that it has awesome hydrophobic ability during that time. It came out as an option to their ceramic wax. So 4 products in the same Sio2 line of products. It's a little strange that they don't recommend to top the CCAIO with the Sio2 wax. So it's seems to be strong on it's own and just use the car soap and QD as maintance. What I have seen so far the cut from the CCAIO is very high and finish great. They use deminishing abrasives and recommend to use very little of the product to polish with. Think this brand would be a big hit if AGO was to offering it. The products I have used so far is top notch.
Hope someone is up to test the Britemax Virtue SiO2 High Gloss Primer Polish. And use it on it's own. If it has that long of longevity as claimed. Then is easy to work with. You could have a big contender in the AIO/cleaner wax segment.
/Tony
Mike I’m totally confused. Isn’t this what Essence already does? Or are you talking about leaving a more durable coating behind?
I’m starting to see AIO’s that leave silica protection behind from other manufacturers.
Im talking or predicting this is a NEW category of products that’s going to grow.
Just like Jeweling Waxes.
Ain't that the truth!!!
I'm a big fan of AIO's. But one of the benefits is being able to polish, wipe, and walk away with some protection. If you have to "top" these with a coating I don't see a huge benefit over using your favorite polish, except maybe you get to skip the panel wipe (although that still seems recommended these days).
Now if these can stand on their own like a traditional AIO then we're on to something. Of course I'm sure it'll be recommended to top them with Si02 sprays (which I personally lump into the category of "spray sealants," Si02 descriptors notwithstanding)
The idea would be a product that is,
One and done
No anything, machine apply, wipe off and done.
Instead of wax or sealant you leave behind coating.
I’m surprised we haven’t seen more of these and sooner to be honest.
With CQuartz lite technology(wipe on - wipe off) one would think an AIO with good cut and protection is right around the corner. I’m am not a chemist tho, so there may be issues there.
Ah yes...
•Good ol’ “Silica Infusion Technology” (SIT)
-It seems the products that Chemists
can stick it into, is endless.
{Pardon my walk down SIT Memory Lane:
...I’ve never been able to totally push
to the sidelines the remarkable results
that Meguiar’s NXT Wax 2.0 always left
on my vehicles’ paint...}
-Sticking some into an AIO, in order to
make it into a CC-AIO, should be a joy
and a delight for many Chemists.
Imagine the Marketing battles that’ll
soon ensue!
I've talked to a few chemists and I think it's a trickier recipe to create than a one-step product that uses a wax or sealant.
I will stick to my prediction though as I think it's just a matter of time.
If there is enough profit from creating these, (and I believe there will be) it's only a matter of "when" and not "if".
Chemists have tackled tougher obstacles than this one. :)
:bump:
Vindicated
The time stamp on this thread is September of 2018
I'm confident this new product from Jim and his team at Dr. Beasley's will perform just as good as thier other new NSP products.
I used the NSP Primers to prep the paint on this car for a ceramic coating.
Review: PBL Paint Coating & Surface Coating - 2017 IFINITI QX30 - Magnetic Red
And used and reviewed the NSP Primers in this write-up.
Review: Dr Beasley's Nano Surface Primers and 1201 Paint Coating - 1947 Dodge Panel Delivery Streetrod
I was impressed with the products overall as well as the abrasive technology.
Cool to see more NSP technology coming from Dr. B.
:cool:
